emanage tuning and installation
Hello Joshua. I want you to fine tune my Satria 1.8 Mivec. Running on emanage blue. How much do your charge? I've changed my intake/exhaust/cam setting. Wanna check out the a/f ratio too:adore:
we charge rm300 for dyno tuning...and to check base ignition etc..
full tune rm300..
josh, for tuning evo3 4wd how much do u charge ? as i understand yr dyno do not have the 4wd facility
Bump: josh, for tuning evo3 4wd how much do u charge ? as i understand yr dyno do not have the 4wd facility
Jos,
how much do u charge for dyno/tune for haltech planted on evo3 (perdana v6)
Bump: Jos,
full tune rm300..
brader Jo.. TQ very much for a satisfying dyno tuning session on the SM4 putih H22A last week.. the car certainly packs more punch now.. gonna try break the XXX whp barrier after this.. u know im very-very close KEKkeke !!
UR DA MAN BRO !!:proud:
Bump:
full tune rm300..
hi to all sifus, just out of interest is there any piggback ecu out there than can completely remove the original MAP sensor ? and ourse compensate it with a MAP sensor.. e-manage ultimate i presume? can it be done?
Bump:
most welcome bro...kekekkeke....the vtec early u prefer or not? its better power band flat curve nicer to drive..no G but definately faster that sudden G...
up a bit more stuff la..
use alluminium flywheel set..with twin plate la..clutch master fx700 go google it...
chun wei....RM4500 only...
Bump:
too expensive la..
by the time u setup ultimate to remove etc...3k ish...
better put stand alone...lt10s...kekeke only rm4k plus install and tune..
yeah, that's what I thought, :hmmmm: , thanks for the confirmation..
vteckiller , juz msg u last night :)
how much you charge for emanage blue(air fuel harness + injector harness) + igntion harness + dyno tuning ?? :biggrin:
safc, u can tekan tekan always lo, like what my friend did.. his 4ag-turbo, using L5 ecu, + VAFC, lolzz funny rite.. but he can always tekan tekan at car lo, but emanage susah sikit la, need laptop.. unless u got the E-01 kekeke more cun la
hahaha
but interm of setting i think emanage better la, 16x16...
at the moment emanage a bit expensive..due to no stock then everybody selling the parts to us expensive..so currently best price we can do is RM1600 plus install and dyno tune and ignitoion harness...
cheers
vteckiller... ok la tu... price still reasonable...
btw.. i'll try to make some time to ur shop to dyno my junk... finally run in already.. sigh.
re-done intercooler piping.. and now some wiring problem... so all these settle edi.. i come see u.. still got $400 at ur place mah.. :)
p/s: the other day got one macha came to ur shop to ask about turbo and mikotek rite? that guy got buy ka? he suddenly disappeared from me edi man.
