e-manage or neo?
jameswwt
1,127
78
1,648
Hi Guys,:wavey:
just wonder is E-Manage suitable for 4G63T turbo engine with its stock ecu? Engine stock and will it be suitable for minor upgrades (change of cams,pulley,intake & exhaust) in future?
Pls advise...
allance
337
Hi Guys,:wavey:
Pls advise...
b4 u install the e-manage,get upgrade all ur engine frist! if not, u need retune agian every u do the upgrade!
veilsideboyz
1,616
17
i thought evo should go for ecu not piggy ? ^^
oh ya...thankss allan !!
i will change to ultimate emanage and give u call to ask more infor...hehe...
jameswwt
1,127
78
1,648
But is E-Manage suitable for minor mod 4G63T engine? Can it achieve 350HP? Lastly,is it stable for handling such a HP? Will the tuning stable? Just worry need to re-tune every few months...
allance
337
dont worry e-manage suit for all japan engine, no need to re-tune if u not doing some upgrade or modification !!!! want 350hp? i think u need to get power FC is more better ,do some upgrade inside engine frist n up boost !
louiswkm
49
is E-Manage able to tune 4AGE + 4Throttle + Turbo?
Bump: is E-Manage able to tune 4AGE + 4Throttle + Turbo?
mivec_mivec
275
e-manage cant support VVT !!!! just can support VTEC , if u get right wiring for nissan neo VVL also can support too...for mivec i am not sure !!! i think u can try connet to mivec wiring myb can works:hmmmm::biggrin:
if so,what add device?is it the same as to put VAFCII connector to mivec?any have tune mivec with e-manage blue?
allance
337
i not sure bro! u try ask to e-manage dealer or tuner! if u want other ecu control ur mivec i recommence u get Unichip guarantee works for ur MIVEC!
Bump:
e-manage blue cannot keh?
olso can bro ! but in ultimate u can tune with 2map for injector(map 1 u can set for fuel eco,map 2 u can set for performance) ,2map for ignition
hai everybody, what i noe for better combustion the car need cold air from air filter to create a perfect combustion,( correct me if im wrong) and can i just make a piping from air filter to my cabin to suck cold air coz im using aircond ... so dat air must be cooler...is it any dangerous?
