qns : improving low-end/torque
t-la
1,080
20
5,138
secret place
turbo10-noted.
seldomly going back hometown, but i will and we will tt or maybe ikan bakar tg dwai......
ok back to the topic...
NA_Lover, bout the piston...shave it.
rbth x 0408
5
hey sifus..
yall r rigth
i on a budget
ahhaa...thats why considering 7a
also due to my location..hard to do mod leh...
how much is a blacktop 6spd halfcut sellin in jb??
NA_Lover
227
Its a bit pricey.. you'll need around 5-6k for 6 speed.
5 speed way cheaper though.. worth considering because rumor has it that the gearbox can take a better trashing. (anyone can confirm this?)
6 speed gear ratio is way closer. Pick up and acceleration is different by a considerable margin.
Then again both will let you FTG! (Feel The Goodness)
km_chew
456
26
3,028
Our synchromesh love to give us krakk krakk sound regardless C52 / 56 / 160 model. Some got downshift problem, while some, upshift. The frequent gear is the 3rd gear.
Best is, make sure you got the best lube inside protecting it. It will definately last longer with a proper graded lube. Driving style will determine your gearbox lifespan too. Saying this, not to deter anyone from trashing the gearbox, just to point out that the lube is very important as it is the only thing in between the gear to gear.
Juz my 2 cents :rofl:
rbth x 0408
5
thanks for the advices again
most probably saving up for a 6spd blacktop in time to come~!=)
any ques from a newbie
seen some videos where ppl put carb on their 4age/4afe
what's the difference between that n the noral injectors?
EDRA
789
4
bro's i want to ask u all is it 6 speed bt ratio for last speed too far? my car can go easily to 195kmh with gear 1 to5 but when engage gear 6 rpm drop much from 7xxxrpm to 5xxx rpm and the speed also drop to 180kmh. i press the pedal but the speed just maintain take time to go up. any idea?
scottwrx
870
24
have you got the speed cut removed? 5th gear call pull longer before speed cut at about 190+, but once u engaged to 6th gear it will cut n drop to 180 n stay there...
EDRA
789
4
scott, yes true my car have speed cut but it is 200kmh speed cut not 180kmh. any suggestion?
Bump: scott, yes true my car have speed cut but it is 200kmh speed cut not 180kmh. any suggestion?
n0th1n
1,161
12
japan
junk-dealer.blogspot.com
5th gear, tyre 15inch,
rpm 7900 (206km/h) and u shift up to 6th gear, assuming fast enough, your rpm will drop to 5660rpm. lost about 2240rpm.
the minimum lost if compare to other gears.
ikankaloi
62
www.e-dcl.justgoo.com
short cut to improve low end/torque .... use a piggy back ( emanage blue) like me.... dont tune wit a dyno machine ---- reading not soo accurate....go for wide band street tune...:biggrin:
scottwrx
870
24
pasang speed meter orr RSM lah.. to remove the speed cut..
cheapest i know that is suitable for 4age is pivot speed meter, about rm250 only.. after using the meter, ur speed cut will be removed.. i also planned to install the meter also
vh-101
546
32
I thought you are using Blitz Access ? Where is your Access ECU ? Btw, where you did your e-manage tunning ?
ikankaloi
62
uinaaa how u know??? kasi kawin saja ba...i got pics of it at my profile...feel free to c .....phewitttt
Bump: uinaaa how u know??? kasi kawin saja ba itu barang...i got pics of it at my profile...feel free to c ..... tuned at Greedspeed by Hamid...phewitttt
Our glory days of getting away with traffic offenses will soon come to an end if the US government approves a bill that requires the mandatory addition of black boxes and brakes override mechanisms to all new cars and trucks. It's not like the decision of the US government affects us here in Malaysia or anywhere else, but if implemented successfully it could create a precedent for other countries, including us...
