What are these meters for
r0yEE
1,775
9
hahahaa for my man titan:beer:and thanks a lot.. will read up..
papa.. your is just a mira, wait till you get a bigger one.. :driver:
shiroitenshi
3,676
170
why having those meters are helpful, in my opinion. They're only good if you can USE/READ them properly.
Vacuum level. this helps in diagnostics. A leaking intake manifold and a lot of other breathing problems can be noted from this. An experienced mechanic can eliminate a lot of possible problems by just looking at how the vacuum meter behaves. If you as an owner notes how your vac meter behaves, you know there's something wrong when it's not reading like it usually does. This is usually for NA only meter, though some boost meter also have the vaccum portion to read off-boost manifold pressure.
Oil pressure level
, also helps in diagnostics. If your oil pressure is dropping, then there is something wrong with your oiling system. Leakage, cavitation, etc, sometimes, maybe just a worn oil pump, or if oil pressure drops during a high speed cornering manouver down in sepang, it just shows that your car can rail through corners at speeds fast enough that you need a baffled oil sump. Some of the tactics people use to avoid this is by OVERfilling the oil sump so that cornering Gs that cause the oil to slosh about is minimized, though at the expense of having the dipstick popping out sometimes, and losing a bit of HP, which losing a little HP is not a problem for high boost turbo cars. VTEC cars suffering from 'my vtec cannot open' can also benefit, by noting the pressure during vtec engagement, which is 40psi minimum, so instead of running about figuring what the problem is: (solenoid, pressure switch, etc.?) though with chipped ecus, this can be bypassed, to the detriment of the engine, IMO. For turbo cars, low oil press means a soon to fail turbo, either from coking, leaks, etc.
Oil temp, prolly more important to turbo than NA, because turbo using the oil to lubricate, and to a certain extent to cool the turbine bearings/bushings, so unlike NA, the curve which temp rises for oil and water is not the same. For NA, apart from the initial warmup, oil and water almost same temp, just a few degrees apart. Hot oil means it's starting to thin out, and that also means less lubrication. It can also give you a hint if your turbo is overheating or not.
water temp
, a cheap way to monitor engine temp, and the sensor practically lasts forever too. Its so you know when the engine is warmed up enough for hard driving.
Fuel pressure, a way to monitor fuelling system. If your fuel pressure is dropping, means something is wrong with the fuel pump or fuel filtering system is clogged. time to change/service. You can base this on mileage rather than using the meter though, so this is more of something for the meter 'enthusiasts'. Though it can also be considered a tuning tool, in the old days, fuel pressure = fuel adjustments, before the days of EFI, when carburetors are norm. EFI also relies on fuel press to a certain extent, but the importance is a lot less than carbs, so for EFI, it's usually set and forget.
Air fuel ratio, a way to monitor a lot of things, but you need to know what the numbers and graph it can output means. It can give clues and hints on misfiring, engine knocks, fuelling or even how fuel efficient your car is. there are two types of meters, one is the A/F ratio that connects to the stock sensor, which tells you nothing, except if your closed loop system works or not. On a car that is emissions friendly, it should register stoich/a little lean at all times at part throttle, and rich at full throttle. A wideband read more sensitively, and can give hints on a lot of other possible issues like I stated earlier.
Exhaust temp
is a way to measure A/F ratio. It is a cost saving method of not having to connect a wideband 02 sensor (which is EXPENSIVE, and spoils a lot more often than the exhaust temp sensor) On a heavily boosted turbo car, wideband 02 sensors spoil quite often compared to exhaust temp, which is why it's a good substitute.
By looking at the exhaust temp and correlating to an A/F meter (which later can be removed), a car owner can notice when the exhaust temp is getting colder (which usually indicates the car is running lean, and stop driving aggresively before causing critical damage (on high performance engines, because stock engines don't see the stresses like modified engines do). Due to the relative cheapness, some budget racing teams mount four or more exhaust temp sensors so they can do individual cyclinder tuning.
For a four cyclinder, 02 price is probably not a concern since it's abt. USD100x4, but imagine those owners with v8-v12s, OUCH!
esp. those with domestics v8-v12. not all american domestic owners bathe in money.
The more extreme the modication to the engine, the more likely things can go HORRIBLY wrong when one component fails, so most racing teams/modified car owners who are technically inclined use these meters to indicate first signs of trouble, and replace the part before critical failure.
Of course, Malaysian people like it because it looks BLING!, which is nothing wrong really, since these people are the ones that buy the most meters, which keeps manufacturers happy and fund their R&D.
r0yEE
1,775
9
:beer:to my man shiro...
thankz loads guys.. now i know what meter should i get for my ride..
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
r0yEE: wait u see those crazed mira owners using big turbos and boosting 1bar++...and get 200% more hp than factory rated... i think they're need all the gauge to monitor their crazy mods huhuhu :stupid:
which i'm not pursuing anyway
thanks shiro for the mega info! can save money by buying only needed gauges.... no time to look at them all :hmmmm:
r0yEE
1,775
9
papa: so true, don't go extreme on mira's man..
shiro san, how do you read if it's good or bad? i know this is a pretty silly question but i just want to know more.. :burnout:
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
I agree that getting gauges that you need is more important then getting all of them. More gauges will only make you lost your concentration on the road only.
papa, i think Oil press is important for you also since your turbo's cooling is taken from the lub oil. if the oil press drop, then you know what u need to do. I think oil press gives you warning faste then oil temp but oil temp is also needed as well.
I think for your setting, Boost , oil temp and oil press is suffice. Intake temp not so necessary if you have sufficient cooling for your IC.
shiro, correct me if I'm wrong. A lean mixture should have a higher EXT temp and a rich mixture should have a cooler EXT temp right?
Royee, some pictures for your reference.
My sister ride with simple setup. Advantage of using DEFI. tidy dash without a lot of wirings.
Like this also can..
Or use a meter hood and mount on top of the center dash. On a Rex.
shiroitenshi
3,676
170
Oh sorry, generally the thought is that way, because on most turbo cars it is like that, but in actuality, due to different ignition timings, the temps do change differently from car to car, and having someone say that 1000C is definitely lean is really mind-boggling, because it doesn't. At peak power, the engine will generate the most heat, so depending on the engine, that EGT may be just right at WOT. there's no specific temp that is similar for all cars.
That's why I said initially the AF ratio meter must be used, find out at what AFR and ignition is getting peak power (a rough idea suffice, no one remembers all the cells in the ignition/fuel maps anyway) and compare it to exhaust gas temp.
Don't be surprised to find that at best power, our EGTs are significantly higher than that of comparable US cars.
The thing is, on the net, the common consensus is that cool=rich, but from what I've learnt, lean + advanced timing also gives out colder EGT readings as well(this is why I mentioned the need for an A/F meter for the first time, because you need to know for sure what kind of temps you'd be seeing at different AFRs at different ignition timings), so yes, it's arguable, and you're definitely right to point it out.
But for owners who don't know how much stoich EGTs are, best have an AF meter to correlate the reading. You can even do a dyno run at the local dyno shop and make a note of it at that time. It lasts longer than an A/F sensor under abuse, that's all i can say. My Bosch LSU-4 died twice already in the span of 2 years plus, though not without me learning how to read my EGT temps on my car..
But EGTs are not so straightforward to read, so do note that it's usefulness as an A/F tuning tool is limited to how much the owner knows about the fuelling and ignition to rely on it as a substitute for an A/F meter.
But for the laymen, you are more right than me in highlighting that colder temps = rich, and hotter temps = lean.
I got mixed up, lol. I didn't notice it on my third reading pass.
TitanRev
Mar 3, 2005
8,180
3,678
shiro, you are correct also. Different cars different readings but you are right that use of EGT should be paired with AF gauge. Thanks bro.
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
r0yEE
1,775
9
yaya jineil, too much $$ to spend on that..
so titan and shiro, you guys were talking about turbo rides rite?
not a non turbo one like my ride ya??
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
non turbo, just no need ext temp & boost meter only...
pioneer411
thats not cool enuf ma... now 'heng' all in 1 ma... hehehe....
http://www.jdm-option.com/eng/parts/05_09/dssc.html
wow no wonder la..8k consider cheap maybe.. i try convert also need 8600rm hahahaha
dunno la maybe discount behind kekekeke...
my question= Those Defi Bf meter de sensor how long time need change one time??? does it expensive to change? because i not sure market about the sensor..
if i buy Defi bf meter izzit include the sensor together? ..
and one case happen to my friend be4..
he buy 6biji meter and control unit from N1 then say include all thing and sensor.. owner at sabah.. me and my friend go buy there at N1 then next day balik sabah.. then sampi want pasang.. my friend cari and cari .. kurang one Sensor... call to N1 they say izzit we no check... or what.. because still kurang one sensor.. they didnt responsible.. and my friend tiada buka be4... then the owner need to buy one more sensor macam Cost so exp... we does check in N1 but seem like kurang something,, and we new to digital meter(normally we use mechanical only)
then me and my friend at N1 see that time got few thing also,, and then they buka each by each say COMPLETE sure enough ...
no body can blame next... blame ourself tak pandai tengok...:banghead::banghead::banghead:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
TitanRev: Thanks for the advice.... wanna start off wif the boost meter since its easy to fit in... then after that, will go for oil temp/pressure....that time for sure rojak wan..... for example lamco boost meter, hks oil temp and omori oil pressure :stupid:
wonder if autogauge are a good brand? :hmmmm:
r0yee: hahaha... for me turbo is just a helping tool for me to overtake/climb hill..... just yesterday, manage to get away from an annoying express bus @ 5th gear on Kl-Kajang hiway.... so easy to get past 110kmh :adore:
The Marketplace Top Posts
I'll make it simple:
"---On 2009-07-24 00:44:00.0 You Wrote Us--- My question is this :- Meguiars Slide Lock Detail Brush - The bristle is made of ??
_________________________________________
Hello,
Thank you for contacting Meguiars with your product question. The Slide Lock Brush used boar hair for the bristles.
Regards,
Michael Stoops
Customer Care Center | Meguiar's, Inc.
17991 Mitchell S.
Irvine, CA 92614
(800) 854-8073 xt175"
Be warned...
