you also can calculate the compression even you are using the 'old school' stuff ...i've boost gsr with stock gsr head stud to 1.7bar with no problem...for me the weakness of the gsr is at the conrod not the head stud....i've use other 'rojak' conrod to solve that problem...:slug:dont use those old school idea..........!
get the compression calculate, adjust it with metal gasket..! head stud can help u to boost little bit more.
yes...both can..i'm prefer ca18I heard that those piston can fit into 4G93T and can boosting more than ori piston. Does anybody knows about that?
u got that right, the GSR conrod is as thin as a lidi.. how to withstand the torture of high boost..you also can calculate the compression even you are using the 'old school' stuff ...i've boost gsr with stock gsr head stud to 1.7bar with no problem...for me the weakness of the gsr is at the conrod not the head stud....i've use other 'rojak' conrod to solve that problem...:slug:
did you ever heard about trg(kmaman) gsr satria that "tapau" many evo/vr4 in mid 20's?even nuar subang been left behind with that car,that car only use cheap chopshop ca18t rod...every mechanic know that hi-peformance rod is good but if they have other alternatives that can cut down their build cost why not?one more thing...did you know how high did that car boost?2.3bar...:cheers::wavey:no offence bro!!!! my knowlage start from 90s! stock running low...! u know wat i mean! we should purpose more new tech! using proper billet or forge stuff, price just alittle bit diff.. from pulling off from 1 complete engine. i know that it can take 1.7bar but go to sepang have a few run than u know what i mean..:cheers: 1.7bar mean every gears up n down..
:wavey:i'm on neutral !this way is not going to boost Malaysia motorsport my friend, that left behind car is not going anywhere, it just have a ok ok power to ratio....did you ever heard about trg(kmaman) gsr satria that "tapau" many evo/vr4 in mid 20's?even nuar subang been left behind with that car,that car only use cheap chopshop ca18t rod...every mechanic know that hi-peformance rod is good but if they have other alternatives that can cut down their build cost why not?one more thing...did you know how high did that car boost?2.3bar...
you are really off from the topic of this thread...the thread starter just want to know if both piston can or not be use at gsr...why you just slap someone by saying don't use that old school idea...i'm not being rude here but only want to make things clear...my self use hi-performance rod/piston for my car and still learning about mod-tech but for it's not nice to shoot someone that willing to mod his car using low cost parts....give them a chance to built their own engine suitable with their budget..not all that loves motorsport have a mountain of money...:wavey:i'm on neutral !this way is not going to boost Malaysia motorsport my friend, that left behind car is not going anywhere, it just have a ok ok power to ratio....
2bar+ is ok with me.....
bet or no bet they should put their name on SIC, to let outsider see it!
i mansion this at BEST TUNER!!!!
the more detail work the better u guys get!!the war is over.........
no matter what piston the important things to check is, make sure the piston speed is in range, bore clearance! fit long lasting/ lose power gain but there is disadvantage n comp
i agree with u coz pulse of engine is the piston & conrod.you also can calculate the compression even you are using the 'old school' stuff ...i've boost gsr with stock gsr head stud to 1.7bar with no problem...for me the weakness of the gsr is at the conrod not the head stud....i've use other 'rojak' conrod to solve that problem...:slug:
Bump:
ca18 can and b8t...i agree with u coz pulse of engine is the piston & conrod.
Bump: then..how about the conrod? also used CA18 or others?
