- Jun 29, 2008
- 887
- 20
- 1,518
Hi guys
Any 4AGZE sifus here? I have a few questions.
I recently setup SC14 in my 4AGZE AE101 MAP engine. Problem is;
When i go full throttle on 3rd n 4th gear at 5-6k rpm, my car chokes or jerks. 1st n 2nd no problem. I only change gears at 6.5k. If i rev slowly to 80-90%, i dont get that problem. Has it got something to do with fuel? or air flow?
I had my ABV removed and sealed. Any problem there? Ive just changed to 440cc injectors hoping it would solve the problem, but it didnt. Im not using e-manage, only stock ECU. I might try e-manage later. I set my AFR to 5 pound, still no luck. FYI, my AFR is Sard (not-so-original). Any problem there?
Im still using stock TMIC, but i guess thats not a problem. My boost is 1.2bar at the moment. cant boost high because of the choke.
I have changed to Supra knock sensor. Still no luck.
And also when the engine is not warmed up, it will lean when going past 5800rpm. But few revs after that is ok. What caused this?
Thanks to those who replies....
