4AGZE & CA18 piston in 4G93T
mrevo
86
I heard that those piston can fit into 4G93T and can boosting more than ori piston. Does anybody knows about that?
hanslin
216
4
:idea: dont use those old school idea..........!
:listen:get the compression calculate, adjust it with metal gasket..! head stud can help u to boost little bit more.
proPIPING
1,077
5
you also can calculate the compression even you are using the 'old school' stuff :biggrin:...i've boost gsr with stock gsr head stud to 1.7bar with no problem...for me the weakness of the gsr is at the conrod not the head stud....i've use other 'rojak' conrod to solve that problem...:slug:
Bump:
yes...both can..i'm prefer ca18:idea:
tajulsans
1,449
9
Soo Bang
u got that right, the GSR conrod is as thin as a lidi.. how to withstand the torture of high boost..
hanslin
216
4
:cheers::wavey:no offence bro!!!! my knowlage start from 90s! stock running low...! u know wat i mean! :idea:we should purpose more new tech! using proper billet or forge stuff, price just alittle bit diff.. from pulling off from 1 complete engine. i know that it can take 1.7bar but go to sepang have a few run than u know what i mean..:cheers: :nurse:1.7bar mean every gears up n down..
proPIPING
1,077
5
did you ever heard about trg(kmaman) gsr satria that "tapau" many evo/vr4 in mid 20's?even nuar subang been left behind with that car,that car only use cheap chopshop ca18t rod...every mechanic know that hi-peformance rod is good but if they have other alternatives that can cut down their build cost why not?one more thing...did you know how high did that car boost?2.3bar...:smokin:
hanslin
216
4
:wavey:i'm on neutral !:biggrin:this way is not going to boost Malaysia motorsport my friend, that left behind car is not going anywhere, it just have a ok ok power to ratio....
2bar+ is ok with me.....
bet or no bet they should put their name on SIC, to let outsider see it!
i mansion this at BEST TUNER!!!!:biggrin:
proPIPING
1,077
5
you are really off from the topic of this thread...the thread starter just want to know if both piston can or not be use at gsr...why you just slap someone by saying don't use that old school idea...i'm not being rude here but only want to make things clear...my self use hi-performance rod/piston for my car and still learning about mod-tech but for it's not nice to shoot someone that willing to mod his car using low cost parts....give them a chance to built their own engine suitable with their budget..not all that loves motorsport have a mountain of money...
hanslin
216
4
:adore:misunderstood!!!!
sorry if i slap anyone...:adore:
:idea:i think we should show the proper way n spare the engine the coming gen...!
:hmmmm:if showing how to ROJAK stuff n saying 2.3bar can take will broke them even worse,they need their car to drove around not reserve alot at woskshop(mod to be last) I'm not arguing my bro! hope u understand!
hanslin
216
4
:biggrin:the war is over.........
no matter what piston the important things to check is, make sure the piston speed is in range, bore clearance! fit long lasting/ lose power gain but there is disadvantage n comp
Bump:
:listen:the more detail work the better u guys get!!
proPIPING
1,077
5
i'm just answer the thread starter question base on my knowledge...peace
ayul
150
i agree with propiping..GSR the problem is conrod..last time i use tdo5 evo3,AFC NEO, boost 1.5...no problem maaa...:burnout::burnout:
mrevo
86
Bump:
i agree with u coz pulse of engine is the piston & conrod.
Bump: then..how about the conrod? also used CA18 or others?
proPIPING
1,077
5
ca18 can and b8t...
The Mini name will be echoing in the rallying world once again after the iconic brand made a return to the World Rally Championship (WRC) with the debut of their Mini Countryman WRC at the Rally Sardinia last week.
Although the marquee, which has tied up with Prodrive for their rally team, will only be participating in some of the rounds of this year’s calendar as a refinement step before going for the...
