naz.....u sure or not standard.......got snail hiding inside ka.....bro..naz here..blue celica 6th gen standard in damansara/pj area..
can yum char ...(office hours) 012 3215761
Hi Bro,
Well those lights could mean that one of ur rear lights is blown, it could also mean, since the car is bit old, that the sockets are dirty, so take out the bulbs and clean the metal socket the light sits in. it should solve the prob.
Oh and abt the projector lights, The are very expensive! it might cost u up to RM3K and is hard to find, a guy from Thailand said can get it for BHT30,000, which is around RM32++, so i was lucky and found them in a potong shop here in KL, sadly one high beam completely smashed!, and other are fine but no brackets, so i took the challenge to make custom brackets
so i have JDM projectors now and im ordering a clear lense (from canada) for my high beams so it will cun.
Also i bought an HID kit with 4300K bulbs, they look really cook, somthing like New 5 series, camry 2.4 and civic 2.0 light, those projecotrs really enhace the look of 6GEN celica (OK enuf poisoning)
bro, thanks for the info on the rear warning light. so how much did you pay the chop shop for the projector light? i am also thinking of installing HID kit as my low beam headlight seems pretty dim. when i turn on the fog light, it gets dimmer. i am not sure if you guys have the same problem. Initially wanted to install 100watt harness and use 100watt bulb, but i was told that HB4 has a max of 70w bulb and 100w does not exist except to purchase PIAA ones which are ridiculously expensive. hence HID 4300 is the next best option. But to get it right, i will need a set of projector headlight to start off.
Some celica parts for sale:
1) ST205 3sgte halfcut RM5000
2) Cusco adjustable for ST182/3/202 1 set RM1500
3) TRD front 3point strut bar for ST202 RM380
4) ST205 front seat 1pr RM300
5) ST205 intake manifold + throttle body + water cooled top intercooler RM450
6) ST205 GT-FOUR rear wing RM500
7) ST205 rear 2pot caliper + disc RM250
8) ST185 fuel rail RM100
9) SSR Type C white original 16X7 5h100 +32 RM1400
10) ST205 spare wheel to pass 4pots brakes RM180
If any1 interested in ST205 full wiring set including meter,ecu,switches,fusebox,n etc, I'll remove it out from the halfcut and sell to you for RM1300
Call me at 012-2249991
7th gen celicas are at www.myjsoc.com you can try to invite them here to make up the number.Updated...
all Celica owners are welcomed
ZTH nick-Celica Generation-Body type-Engine-Color
The list has 6 and counting...
Barbarian-7GEN-ZZT231-2ZZGE-silver
Bytes-6GEN-ST202-3SFE??-??
Freeguy-6GEN-ST205-3SGTE-white
Naz-6GEN-ST202-3SFE-light Blue
Tom's-6GEN-ST205-3SGTE??-Black
Zeus83-6GEN-ST202-3SFE-Red
bro my id "zeus" still not active at myjsoc:rolleyes:...7th gen celicas are at www.myjsoc.com you can try to invite them here to make up the number.
thanks,Tom, good stock h have there
do u have the GT4 raiser blocks oni?
any pix of the ST205 seats?
TQ
ouch.... looks like I'm not welcome here......shouldnt we just keep this post for 6th gen. easier to share technical information. or maybe Zeus can start one for just 6th Gen.
Zeus... pls register again and I will activate you.... I'll delete your old acc now....
Edit...... Zeus, pls ignore my above statement... your nick has been activated....
sorry barbarian, didnt mean the intention of not welcoming you, just that i think there is not that many 6th gen around, so it is sometime a bit hard to share tech information. Many times i bring a car around and even mechanic dont know what car it is, let alone fixing it... :) dont take it personnal bro..
thanks,
what do u mean gt4 raiser blocks??!?!
the ST205 seat is the same as other 202
