how does hi cam work?
EDRA
789
4
any expertist can brief me why people use hi cam to increase speed? how does it work? what are different with normal cam?
boosook
378
2
Shah Alam
its very technical, try reading "how engine works" first at www.howstuffworks.com
for high cam or performance cam, the degree of the "water drop shaped" thingy the moves the valves at the camshaft is different from stock. different degree gives different loop time. longer open loop time will give u more air thus more fuel is mixed thus better combustion = better power.
correct me if im wrong.
nitrus
2,895
35
1,648
Hi cam are cams that are mounted at hi altitude to snap hi quality images.. They serve to increase speed by using the most advance.... Just listen to boosook.
Sarb
68
"water drop shaped" - the word you are looking for is "cam profile". High cam is where the cam profile loop is bigger to provide more valve lift, and the cam profile curvature is smaller to provide longer time for valve lift (for more air intake or more exhaust out)
Sarb
68
cheers!:itsme:
retrofit1
55
2
1,508
Hi,if i change to hi cam...do i need to install piggyback/safc as well?
clanzkiller
1,394
27
1,648
is an option for u...because piggyback/standalone is an ecu which mean to manage your engine...
is better to install if u got the cash...
a safc wlil do
Choon
117
Perak
anyway, hi cam will exert more stress to your valves because of the more sharp curvature on the cam profile, which might shorten the life of the stock valves.. correct, sifu sekalian?
and now gasoline price went up ad, dun use high cam lo.. use more fuel oni.. haha :biggrin:
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
nope... valves are not wear n tear item... sharp curvature of the cam lobe means higher lift on valves to allow more air/fuel to go thru....
camshaft with high lift recommended to upgrade stiffer valve spring... stiffer valve spring allows valve to go up and down fast and precise so ur piston wont hit ur valve...
Choon
117
Perak
no ah? i tot i read it somewhere.. when i found the info then i paste back here la.. ahha
retrofit1
55
2
1,508
sifu sky,i'm using 4g13p...satria mmc batch.i plan to install hicam to increase torque.what duration do you suggest? do i have to change the valve spring as well.how much ar?:hmmmm:
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
the normal one, 272 degree would be suitable... reasonable power increase but with minimal (not none) effect on low end and driveability... get it tuned properly and it will perform...
as for valve spring... i'm heard some sifoo using standard valve spring on 292 cams no problem... while the other sifoo using 272 cams on standard valve spring KO'ed....
so, i guess it fairly depends on the condition of ur valve springs... if ur duration and lift of ur highcam is alot and often high revs, it is recommended to upgrade to stiffer valve springs...
my 2 cents...
CarroTT
177
the "hi" on the hi cam usually refers to the "lift" that the cam exert to make the valves move down n up.
a hi cam will make ur valve being pushed down lower to open wider , thus giving less resistance to flow.
the peak of the loob are higher for a hi cam, not neccesarily wider or fatter.
Just to make the valves open wider.
being specific on the term "hi" oni
duration and position of cam is more usual to be described by "long" or "length" and "degree"
!!!need help about custom car approval
all sifu out there or any 1 experiance
do i need JPJ approval after i fix some custom made body kits(car look different then original e.g. kenari mod to accord) to use it on the road???:Not_Impressed:
