DIY - Cleaning Your Thorttle Body
martinchan
1,037
Ipoh
Hi There, I Had Discover How To Clean Our Thorttle Body By DIY
First Remove The screw Of The Air box
2 - Same Remove All The Screw
3 - Remove All The Joint And Socket, The Coil Of The Arrow Should Be Easly To Remore
4 - If The Coil Hard To Remove Then You Need To Remove This Two Nut 1st
5 - Same Remove The Socket
6 - Same Remove The Socket
7 - Romove This, But BECAREFUL Once Remove It will Leak Out The Coolent Water, It Maybe Hot Depand If Your Car Engine Still Hot, So, I Recommend You Do This Before You Start Your Engine In The Morning.
8 - Last, Remove This 3 Nut To Taken Out The Thorttle Body
9 - This Is How It Look Likes When You Take Out The Thorttle Body
10 - Dirty
11 - Clean It With Fuel Petrol With Clean Cloth And Gentle, Don't Scratch It
12 - This Is How It Look When Finish Clean It
So After That Just Screw Back All The Nut And Socket Then Reset The ECU And Start Your Engine To Wait It Self Learning, The RPM WIll Go High And Low , But It Is Normal During It Was Self Learning. So No Need To Worry.
tengsh
76
waaa........ martin goin to open workshop already...... anyway nice info :adore:
martinchan
1,037
Ipoh
hehe.. i wish to.. but no supporter....
Northiswara
2,589
7
how many hours u take to dismantle and clean then assemble it back?
Northiswara
2,589
7
lamer2000
7
Bro,could you post the picture again for the DIY throttle Body Cleaning cause it got deleted.I am interested to DIY throttle body cleaning
zahir_zahari
58
Bro, do you know how to reset ecu for Wira SE.because i plan to clean my throttle body this weekend.Do we have to reset the ecu after cleaning the throttle body for Wira SE?:confused:
ST56J
125
Can reset ecu for wira? wow.. malaysian technology is really picking up..
jedi
108
4
3,018
10 - Dirty
hey bro
the photos are missing
mind checking it ? thanks a lot
nickleesoo
84
wah!!!!!!! martin now super famous man...... faster open shop, i will support you all the way bro.
Bump: wah!!!!!!! martin now super famous man...... faster open shop, i will support you all the way bro.
martinchan
1,037
Ipoh
hoi buddy!!! Long time no see huh??? when are coming to ipoh visit me again.. i got something for you !! hehehe..
nickleesoo
84
wah! martin kor kor.... u got what for me? i now in vietnam la. only come back every 2-3weeks. so, it's better you come down la and can yum cha with the 3 uncles [me included of course]. i bet you uncle yew and uncle teng sure agree one!
Nuries
if go to shop usually they said to replace the new throtle body that cos around 800 walau-eh
jedi
108
4
3,018
but some foreman touch the bottom part of the throttle body and says that the plastic or something like that was melting and this TB is dying.
they say its useless to replace the small gears or open & clean it.
i am not sure how true was it.
Veni Vidi Vici - It came, it saw, it conquered. Nardo, the epitome of high speed on the fastest oval track in the world.
October 21st, 2007. A 4am wake-up Espresso has to suffice. The remaining drowsiness disappears as soon as the 6.5 ltr. V12, now with 663 hp, is fired up. Re-torque the wheels once again. After checking the pressure of the new Continental V-max tires the edo competition LP 640 Versione Nardo rolls onto the 12.6 km (7.8 miles) long oval.
Each contestant has 3 laps: The...
