DIY the "probably the only real FUEL SAVER"
Jimslec
275
29
5,028
Guys, anyone who had assemble or prepare materials for this project...can post up some pix ah? Share, share on how to DIY mah.
-storm-
96
I done mine cost around rm50++ .....im using stainless steel so far no rust yet but rod im using rusting already because not pure stainless steel.
donCityZ
2,293
33
1,648
buy the stainless steel bolts and nuts la.. wont rust..
but hard to find.. my fren bought for me in Kepong..
Northiswara
2,589
7
SS bolt and nuts cheap larr bro.
1 pc of bolt and nut which is about the size of a pencil and length 3inch cost u nearly RM1 at hardware shop.
u go hardware shop find. got a lot larr.
-storm-
96
I cannot find pure stainless steel one,all the hardware shops i visited say stainless steel expensive so they not ordering it but instead are selling partial stainless steel. i got the whole rod at rm13 very long enough for at least 3-4 projects.
jasonxxxin
42
bro, you see that i just registered and put my first post, broke my "virginity", hehehe. actually i have already surf this site long ago to find deal on car stuff, just did not post anything and dont need to register. but this topic is very interesting force myself to add my 2 cents too. anyway to all the DIY sifus, good luck and share share any improvement in your FC since the price of fuel will surely go up next year... cheers from snail racer
Northiswara
2,589
7
storm,
yeah SS is very expensive now. maybe can get pure SS from the SS engineering that build SS gate. my office has SS staircase rail which i am thinking of cutting it for my DIY project. hehe....
-storm-
96
storm,
:rofl:Later got ppl fall down because no rails to hold on to
csl
1,285
498
1,683
Malysia
Ultimate fuel saving device. Also increase braking efficiency and brake pads wear/tear. Can help the engine oil last longer. Price very cheap, RM2 each :D .
icecube
596
3,018
Found a very nicely built unit running in a van.... look like KL plate number... view here...
YouTube - water fuel generator
and this fella from malaysia ... he got one video running two unit of it!! salute!
YouTube - water fuel generator double unit
add in..
click on the "more details" button and u get these info...(jusst sharing the info)
"Hydrogen booster can save minimum 20%~ 50% gasoline & more mpg for your combustion, installation of the fuel cell @ unit Ringgit Malaysia 599.00
134,Jalan Sungai, 57100, Kuala Lumpur
Tel: 012 2121 718 & 013 236 0022"
Northiswara
2,589
7
u need transformer to turn 12v to 2v.
i think watt is used to describe how much power and heat produce not volt.
nice clips.
-storm-
96
nice clips.
No need transformer la, just some resistor will do the trick, but make sure you use the right value, im so noob at electronic stuff must ask my engineer gf :biggrin:
icecube
596
3,018
ya resistor will do the job but i wonder how do we calculate the ampere once its down to 2v .... how much ampere would the 2v able to take?
after much read up from some pdf files i download off waterpoweredcar.com,
its best to have 7 cell (a pair of + - make one cell) to benefit from the full 14v (generated by most car alternator).
So, to make it abit more simple for noobies like me (and some of us here), i think we should start building one cell first and move on from there........ as many stuff we need to take into consideration such as the following....(quesstion i might need clarification if any one knows the answer..)
1. Under bonnet space and location of the system.(eg.away from heat?)
2. Do we need a bubbler? (a safety and filteration system).
3. IF yes, back to question 1.
4. Where to get the one way valve (to prevent water flowing into the engine)?
5. As i know we do need fuses and relay, based on a one cell design, how much amp of fuse should we use? (i think we have to run it thru an amp meter to check the value if i am not mistaken)
6. how large would the plate be ? bigger would take up higher amp draw from the battery/alternator?
i think thats some little question i have for now...
Northiswara
2,589
7
icecube, u sure got a lot questions.
i will try with SS bolts and nuts with baking soda then i post the result. but recently quite busy.
donCityZ
2,293
33
1,648
holy crap... some people just always got the time to do this...
salute!
but any reports on the Fuel Consumption before and after using it?
i still skeptical if running on Fuel Injection engine...
Northiswara
2,589
7
doncityz,
there are professor marr. of cozs they got time to do this. or else how can they known as professor.
Northiswara
2,589
7
want to patent it and market it?
H2 is a danger gas and can easily BOMB. it needs to go thru a lot testing to make sure it is safe b4 u patent and market it. or else if got problem ppl sure find u and sue u kao kao cozs u got the patent of the thing which prooves that u are the inventor of it an u will have to responsible for ur product if it brings harm to ppl.
storm how is ur H2 generator? good?
-storm-
96
No time to test la changing car already, wont be testing with my new car =p later premature rust pula. Btw H2 is not really that dangerous if u dont compress it, if its burn also it only burn like 1milisec and it takes a lot of H2 in the atmosphere to really cause any harm. Hindenburg all survived and those who were kill fall to their death and not burn to death.
hi guys..was wondering wats the purpose of banana manifold?
to reduce restriction?
mostly i can see it on turbocharged cars...wat about a banana in a NA car?
will it serve any purpose?
thanks for the reply!
cheers and have a nice day!:_:
