29,998
price here also inclusive of new valve, installation, balancing and nitrogen air. Add RM10 for metal valve. Honestly, I don't know what is the benefit of filling in nitrogen air.
Actually air is already 78% nitrogen, more worried of water vapour in the pump you use. More water vapour then the more the air pressure will go up due to the heat build up....
Reactions: minibeany
KHNG940413
KHNG940413
668
56
johor bahru
Wira update
I don't know since when,my car cabin can smell petrol scent
Driving everything is ok,just after I park my car for a period of time when I go inside my car the petrol smell is there.
Is that any possible something might leak?
Wira update
the petrol tank has a ventilation outlet, just check to see if there's a leak or tear there. Also check your fuel filter, when was the last time you changed that?
KHNG940413
KHNG940413
668
56
johor bahru
Ok,noted wilk go and check
The fuel filter I had change on last year. Might need to change already I guess?
Very short period of time only la.. can't be the filter. You better check your fuel tank ventilation hose. Just open the fuel cover and trace that hose to the tank. See if it's leaking or not or cracked.
to all sifus,im new in this motoring industry.. bought a 2nd hand with 90xxx mileage.. my questions are. when is the time to top overhaul and when is the time to do full overhaul? is there any sign? what is the cost for top overhaul? and how about overhaul? what parts are replaced on top overhaul and overhaul? hope all sifus here can answer my question. newbie here needs some knowledge
