Car Alternator or Battery Issue
Bro, he has idle issues. Alternator not supplying enough during idle. Like I said earlier, if alternator consistently undercharging, the battery simply goes flat very soon
simply need to drive faster :rofl: :driver:
sweelt
Nov 6, 2016
2,306
248
my wira cruising like 13.5V with aircon ON or OFF.
When idle, aircon compressor kick in it drop to 13.0V (rpm also drop) for short moment then regain 13.5V normal idle 900rpm.
May i ask , is it aircon compressor problem or "berat" ? Idle rpm take a dive to 600rpm momentarily.
parakey
1,367
226
A car at idle is not at it's most powerful rpm. So when compressor kicks in, it places an additional load to the resting engine. Hence rpm drops momentarily till ISC takes effect and raises the rpm to compensate
Yes, due to extra force required to turn the compressor, that is hwy need the FICD/IACV to increase the idling speed......
Mitevo7
1,456
179
Hi All,
Since sweelt talked about A/C, just want to check, if alternator has not enough juice, will that affect the timing of A/C compressor kicked in? I found out that the A/C is slow to come in during slow traffic, where RPM constantly stays below 2k rpm. Once got on the free way and the A/C works just fine.
Thanks,
Ken
Hi All,
Thanks,
Ken
Not enough juice..
Worts if the compressor clutch is worn out as the compressor wont engage.
dear ZTH members...
What should i do for my v6 6a10 engine to up the power ???? what type of piston should i use if i want to bolt on turbo for my v6 6A10 ???? the original pistons size of my v6 is 73mm... its too small.... any idea to power up my v6 6a10 ???? plzz help me.... urgent !!!!
