Fiat Coupe
es86
Feb 17, 2015
25
2
503
Have you tried chop shops? New part would be hard to come by. You sure the fan is broken, or the relay spoilt?
hi iseo, thks alot4reply, yup d fan itself is ok, but mechanic says d moto is worn off, its goin v slow, fanspeed is even weaker dan d ac fan, ukno.. after20yrs.. so we r searchin4d moto replacemen now, stil searchin.. anyidea wercan get? used o compatible wil oso do
es86
Feb 17, 2015
25
2
503
n thks guys4feedbak, ya we r actualy tryin al sorts ofways, incl chopshop, if realy cantget, got2consider modification.. gluck2me haha
Straight change to a SPAL fan la.
es86
Feb 17, 2015
25
2
503
its a brand. Well known to produce very good performance fans.
Oic, thks bro! My mechanic manag2mod in a fan, from chopshop, afte alongsearch, dono watbrand.. but workin wel, v v powerful, but d problem is, temp stil gohigh!.. alamak.. gues d nex suspec wil b d radiator huh.. perhaps isud havit clean n c how itgoes.. lovlyday
ixeo
4,788
3,080
KL, Malaysia
Temp go up during car moving fast or car idling?
Need to trouble shoot, find out what is wrong first. If radiator dirty then need cleaning.....
es86
Feb 17, 2015
25
2
503
bothway.. goesup even faster whil idlin. wehav infac change d fan, wich is obviously necesary cos its old n movin v slowly, afte changin d fan, temp stil gohigh, once i start dcar, it goes over90 in15min o les.. mymechanic suges hav d radiator chekout, so i senit2radiatorguy, dey tok alok n says dats ori rediator, not worthit2clean cos som corosion alr ocur externaly, internaly mus b worse, beter change d fins, d frame can reuse dou.. uguys thk dats reasonable mov? tq
es86
Feb 17, 2015
25
2
503
higuys, jus wana infom dat ihav replace2fans, radiator fins n radiator cleanup, but its stil boilin.. movinfas is ok, bout70degre, jamtime movin slow its90, idle.. boil in lesdan 15min.. any sugestions pls? apreciate n lovlyday
scoupe
1,087
37
5,148
shah alam
how are you monitoring the temp? external gauge? like vr2 asked, how is the flow? checked to see if the thermostat is opening fully? since you said boiling, had a look at the radiator cap? i am not very familiar with fiats but what temp does it normally idle at?
is it possbible to DIY lowering the front part of the bonnet? I mean like tilt a bit lower down... cause my engine so damn dirty la... cannot tahan... worst thn WRC car(heh heh)
sifu sifu plz help...
:biggrin:
