Instead going up 20 you went down 20.....lolThat's insane! The AD08R were 245/40, 265 is too much.
Bro you have over 360 freaking turbo horses to the ground without traction control! I only have half that and I already use 245 tires. BMW 328i F30 MSport with only around 200WHP with all the electronic aids already uses 255 tires. You see yourself how much space you have left with your current size, so going up another 2 cm will be just nice. I suppose you'd have good driving skills to tame this beast....
Hahaha that's what I thought so too. If wants to drift then yeah, use less tires. For me I want the most grip, coz no skill to control drift leh.You not oomph kaki mah! He wants wheel spins......hahhahhahahhaha
Not the skill issue, it's the offset and rim size. These rims are 8J. To fit 245/40/17 which was what I was on - the offset were taken from a 5-series and the rim even though 8.5J wasn't wide enough. I'd need to find 9J or 10J rims for this car with the appropriate offset which is hard la to fit 255/260 profile tyres man. Right now with my 225/45/17 the car is light on its feet compared to the old 245/40 rear setup. Ok la.Bro you have over 360 freaking turbo horses to the ground without traction control! I only have half that and I already use 245 tires. BMW 328i F30 MSport with only around 200WHP with all the electronic aids already uses 255 tires. You see yourself how much space you have left with your current size, so going up another 2 cm will be just nice. I suppose you'd have good driving skills to tame this beast.
Since downsizing, I haven't had a single case of wheelspin la. 1bar boost and 268ftlb of torque isn't enough to spin anything much less the wheels.You not oomph kaki mah! He wants wheel spins......hahhahhahahhaha
Unfortunately no LSDHahaha that's what I thought so too. If wants to drift then yeah, use less tires. For me I want the most grip, coz no skill to control drift leh.
Btw this monster got LSD or not?
1. True. I am square at the moment. Might go 235 next round but tyre brand choices is extremely limited.1.Remove the flare, square always better for handling. Unless you wanna be about the looks > handling. Staggered setup will induce understeer - science
2.Oil cooler fan? Is it necessary? Most oil cooler setup seems fine if you have airflow/ducted
3. 245 width is plenty for a square setup. On a BMW F30, Apex Racing (guys who make rotary forged rims) recommend 235/40/18 as the ideal tire size, with 245/40/18 also a viable option for track setup. I'm pretty sure there are guys winning races with 235 over 265.
https://f30.bimmerpost.com/forums/showpost.php?p=20103850&postcount=8
Pasang LSD la tunggu apa lagi.Since downsizing, I haven't had a single case of wheelspin la. 1bar boost and 268ftlb of torque isn't enough to spin anything much less the wheels.
2. Actually I don't know. Right now I am having high water temps in jams which is my main issue at the moment. If I re-route my oil cooler to the side it'll have it's own cooling route/duct but nothing when in a jam so not sure if I need one. I'm researching this at the moment.
3. I don't want to go 18 la. Come on man - on a daily that's overkill. Until I'm truly confident the car can take the punishment I don't think I'll ever want to bring this car on track. And 18" tyres are by no means cheap! (The models and brands I want aren't. Don't tell me there are cheaper options at the expense of grip and safety).
Auto lerr... apa clutchbuild the rev! dump the clutch!
haha obviously u still didnt whack it hard enough...
my 2xx whp awd still manage to spin light-loaded wheel side if i hoon it 225/50-17 tyre
235/40/18 is too small in terms of overall diameter for F30 so the fender gap is bigger/uglier, and the tire is too thin profile, will be harsh ride. 245/10/18 is minimum for car this size.1.Remove the flare, square always better for handling. Unless you wanna be about the looks > handling. Staggered setup will induce understeer - science
Waa so much power yet only use 225/45/17?? 8jj can still use 245/40 actually, just like my fronts now, will look just nicely square on the rim. To fit 255/265, can use 9jj enough already. Seriously 225 is way too small for your car, especially with that much power. My wife's Livina is using the same tire size as yours also. :lol:Not the skill issue, it's the offset and rim size. These rims are 8J. To fit 245/40/17 which was what I was on - the offset were taken from a 5-series and the rim even though 8.5J wasn't wide enough. I'd need to find 9J or 10J rims for this car with the appropriate offset which is hard la to fit 255/260 profile tyres man. Right now with my 225/45/17 the car is light on its feet compared to the old 245/40 rear setup. Ok la.
As bro pomen said, that means you're not yet whacking it hard enough. :DSince downsizing, I haven't had a single case of wheelspin la. 1bar boost and 268ftlb of torque isn't enough to spin anything much less the wheels.
Huh automatic??? I thought all this while was manual wor!Auto lerr... apa clutch
SPAL will come. Just wait for budget la. Not cheap leh. And LSD you think drops from sky meh. I'm still fine tuning my exhaust, it's still on the side of too noisy and stinky.Pasang LSD la tunggu apa lagi.
Told you already for so long liao, change to SPAL fans bruh. Don't kill your 5 figure engine just because of rm1k+ fans. Oil cooler most people wouldn't need a fan. I plan to enter Sepang one day so I'll need all the cooling I can which is why I installed a fan on mine. Normal drive or occasional Genting, no need fan also can.
Nabeh.. apa auto. R154 is not an autoAuto lerr... apa clutch
huh.. 8JJ with 245/40 is stupid la. Like I said the old tyre and rim combo for the rear was 245/40 and it was barely holding on in terms of sidewall. Minimum need 9JJ and I haven't seen any that I like or can afford. Slowly la. Your Livina using 225/40/17 is insanely huge.. maybe I'm just used to smaller tyres.Waa so much power yet only use 225/45/17?? 8jj can still use 245/40 actually, just like my fronts now, will look just nicely square on the rim. To fit 255/265, can use 9jj enough already. Seriously 225 is way too small for your car, especially with that much power. My wife's Livina is using the same tire size as yours also. :lol:
Holy shit man I thought yours was an auto weyh. God damn rare unicorn you got there man 1jz manual BMW e46. The body itself was originally manual or auto though?SPAL will come. Just wait for budget la. Not cheap leh. And LSD you think drops from sky meh. I'm still fine tuning my exhaust, it's still on the side of too noisy and stinky.
Today I managed to test top speed on the car and I think I want a 6th gear. Thank god for digital GPS speedos.
No.....top speed cannot reveal now.Holy shit man I thought yours was an auto weyh. God damn rare unicorn you got there man 1jz manual BMW e46. The body itself was originally manual or auto though?
How much la top speed? Share screenshot pls Hehe
You thought it was an auto? Seriously? Haha! Not really rare to be honest. The body was originally auto unfortunately. Top speed I can't screen shot cuz I drive with two hands la. Need both hands!Holy shit man I thought yours was an auto weyh. God damn rare unicorn you got there man 1jz manual BMW e46. The body itself was originally manual or auto though?
Haha! You're hired as my personal line queue manager man. LOL!No.....top speed cannot reveal now.
It will be reveal during riding shotgun to lucky few only.the rest need to fill up RM30 of RON97 to qualify for a ride.If recommend more than 3 friend cam get at RM10.
Just remember...the owner will be driving.If you wish to drive, need to sign LOU complete with COA chop and sign.
how fast ur heart rate ? lol...SPAL will come. Just wait for budget la. Not cheap leh. And LSD you think drops from sky meh. I'm still fine tuning my exhaust, it's still on the side of too noisy and stinky.
Ya weyh I thought it was Auto Haha. Old man liao usually find auto car maYou thought it was an auto? Seriously? Haha! Not really rare to be honest. The body was originally auto unfortunately. Top speed I can't screen shot cuz I drive with two hands la. Need both hands!
I get to skip the queue because I gave you taxi ride last timeHaha! You're hired as my personal line queue manager man. LOL!
He put heart and soul into this already, if auto, he wouldn't bother too much.....hhahahhahahYa weyh I thought it was Auto Haha. Old man liao usually find auto car ma
Screen record the screen during the run la then can see 0-100 times one shot also hehe
