Recommendation for Stainless Steel braided hose
djandrew
10
22
That is one very important point. ABS pump need computer to do the bleeding.Normal bleeding wont remove air bubble as the pump is not operating.
yes i ask them twice already did they do the abs bleed the service center foreman said yes, and he said he also take out the master pump cylinder and check he sees ok.
djandrew
10
22
Whoops.. SuperCircuit yes correct.
It sounds like your installation is screwed up. Did they bleed the ABS pump a well? That needs the computer thingy to engage ABS to bleed it. Cylinder, Servo, ABS pump - these things need to be bled once you take it out. This kind of spongy feel has nothing to do with the brake hoses.
this is what i worried, but i asked them few times already did they do the abs bleeding he says yes. master pump he says yes checked. servo i ask got problem or not he said servo is fine. no point keep arguing with him lol. what i worry is they didn't do the master pump bleeding nicely, not the cylinder bleeding that is the last part. by the way u're right by logically spongy nothing do with the brake hose between rubber and steel braided hose when applying normal light mid pressure pedal while traffic jam time. suppose steel braided hose only when hard pressure time the kick in might be more biting compare to rubber hose. my situation now is full pedal confirm is biting full stop one, just that the light foot normal mid pressure pedal biting is not that griping to rotor.
I'm using Pro-RS for almost 6 years now, works as expected and no complaints or any issues.
leinnz
333
57
3,028
Hello djAndrew, 1st time see you here in ZTH.
Maybe your General CT bite is not as good as your previous set?
djandrew
10
22
yeah maybe tho, but i think more or less general ct adequate with stock grip level. but 1 thing usually 1st pump pedal will deeper then 2nd pump will not sink so much already gets tighter up. i asked some of my friends they said theirs also like this. maybe toyota dna perhaps like this?
Either still have some air bubbles or just let it bed it further. Later still like that probably need another round of bleeding....
i would personally prefer to test the car myself before I make anymore comments. I have the 1st and 2nd gen Myvis and both have different brake pedal feels.
Guys, anyone tried doing a light dimmer in your cabin? Like those BMW when the door closed, the cabin light will only goes off after a few seconds. I have tried the following circuit. Having problem... Yes, the circuit works, but the light only gets dimmer, really just dimmer and doesnt go off. Can someone share how to improve on the circuit or if a better circuit to share? Thank u.
[FONT=Times New...
