Satria neo campro modification done, 117 hp only
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
im no expert when comes to NA engine. but 1 thing i know, tuners from USA will always mod thing that are need to in order to improve a step more. example, change filter or open pod complete with cold air intake and heat sheild so that ur air intake temp is lower thus can be tune for more power. exhaust manifold to muffler change using the best option they have. then use better fuel like E85 or race gas. but in our case maybe v-power or petron 100. then during dyno tuning when the engine needs more fuel, they upgrade fuel system. bigger fuel pump, regulator and injector. when they found out the dyno graph peaks not good enuf, they upgrade cams and head porting.
so the moral is tuning up engine power is actually learning the engine step by step.. but when u start, start with the heart of the engine which is the piston rod and crank.. then everything else follows it.
mADmAN
1,840
547
looking at the earthquake of a graph... i think it needs a retune...
sweelt
Nov 6, 2016
2,306
248
good summary there bro 4gbanger :biggrin:
Anyway safety first, lol....
khaiirrul97
19
How much cost roughly to change to cps’s IM or change to skunk’s or any other recommendations? Sry if the question sounds stupid.
n heres the chart for that last time discussion,glad to hear any comment :|
What is your aim?
Outright hp, overall driveability,etc?
sanekit
Dec 9, 2015
1,616
157
this is after tuning with the same spec u listed before? got additional stuff? your afr look unstable.
khaiirrul97
19
Yep the same spec from before, the afr idk , is it because of speedcut or anything, my brother’s the one who bring it to tune and he said the speedcut is at 200, n yep can feel the meter can go beyond 200 but it stop at 200.
khaiirrul97
19
anyone know hp of stock cps and cps r3 on dyno? Not based on proton one :hmmmm:
sanekit
Dec 9, 2015
1,616
157
Yep the same spec from before, the afr idk�� , is it because of speedcut or anything, my brother’s the one who bring it to tune and he said the speedcut is at 200, n yep can feel the meter can go beyond 200 but it stop at 200.
eh? got speedcut meh? i see your revcut is at 6500. should be correct right?
cps stock is 125hp at the crank
R3 is 135hp at the crank
khaiirrul97
19
Both my brother n his friend said got speedcut, they went together to tune. Maybe not the latest dyno chart that they gave me if u say otherwise. For the hp, at wheel estimated how much?:hmmmm:
sanekit
Dec 9, 2015
1,616
157
Proton never put any speedcut on their car. Maybe coz not enough power to get pass 200kmh. And your latest graph can see spiking at high rpm also.
khaiirrul97
19
Not proton put speedcut, my brother put, he said the car is unstable because no struct bar yet. So he decided to limit to 200, that’s what he said la idk lor. Spiking of graph usually tells what? (E.g. unstable spark?.,etc.)
It looks like Germany's autobahn system is safe from a potential increase of speed-limited areas, for now at least. As posted on numerous occasions, environmentalists, the European Union and even citizens of Germany have called for the adaptation of 80 mph (130 km/h) limits in the currently ungoverned sections. However, today the Chancellor of Germany, Angela Merkel, publicly rejected a proposal aimed at reducing automotive...
