My waja is using N70 bit mine is Renault engine.How abt the wiring?
Thanks for the info guys
So there are possibility you dont need to change the holder and clamp.
if got space, dun need relocate.How abt the wiring?
If I recall - it's the CCA (current) amount that matters, the DIN is the size. BMW uses those deep cycle batteries for longer lifespan and it can handle the sudden draw of current. Normal batteries will have a very much shortened lifespan if used in a car with large draw.1) Why does conti like BMW need to use DIN type batteries ?
2) If use smaller size like NS40 for bigger cc, what is the negative effect ?
Hope your alternator can support the bigger battery. Otherwise you're just spoiling the larger battery faster.Iam using ns70 for my gen2 without battery bracket, well iam not using my gen2 for touge driving. Its just a town car.
The main reason for using ns70 wet type is basically financial reason.
1)ns 70 last longer than small battery.
2)ns 70 wet type will last longest from my reading.
3)ns70 has much better CCA than ns60, its a better choice if you relocated your battery. DIN type battery has more powah than NS type battery.
4)better gounding,its a must, grounding cable shall be exact or better size than the power cable.
Have a nice day
NS70 can lah! Bigger probably cannot......lolHope your alternator can support the bigger battery. Otherwise you're just spoiling the larger battery faster.
Figure out where to put bracket. Duno when will hit pothole, battery jump. We dun want postive terminal touching body. Maybe tiny posibility, but play safe.Iam using ns70 for my gen2 without battery bracket, well iam not using my gen2 for touge driving. Its just a town car.
Have a nice day
Just buy the bracket RM7 to 10 onlyFigure out where to put bracket. Duno when will hit pothole, battery jump. We dun want postive terminal touching body. Maybe tiny posibility, but play safe.
Doesn't work that way. Need to change the tray and bracket hook position. My car fits NS60 and 70, but the 70 can't fit the brackets even with the newer bigger ones. Damn kacau.Just buy the bracket RM7 to 10 only
Mine no tray, just find another place to hook at the bottom. My old school probably have plenty space until newer cars and my Hyundai uses the bottom clamp to hold the battery. That is why need to buy battery with the notch at the bottom.....Doesn't work that way. Need to change the tray and bracket hook position. My car fits NS60 and 70, but the 70 can't fit the brackets even with the newer bigger ones. Damn kacau.
Speaking of which the NS70 I bought had a base that was jutting out. Damn damn damn kacauMine no tray, just find another place to hook at the bottom. My old school probably have plenty space until newer cars and my Hyundai uses the bottom clamp to hold the battery. That is why need to buy battery with the notch at the bottom.....
Brother, you sure...Proton spend money to make
a) Waja cost = RM1.2 billion
b) Gen.2 cost = RM1.3 billion
c) Savvy cost = RM850 million
With that cost Proton should produce car like Camry, Vios, City but sadly to said ....................... then compare with Produa
a) Myvi cost = RM580 million
Based on that figure, cost lower but quality & performance 3x better than higher cost................... What happen?
