ATR Gear slip
xamel1975
20
3,003
Hi,
My Trekker have this problem where the gear slips when it's hot.
I changed the ATF with treatment fluid. And a check on the ECU shows an error P0170 - fuel trim bank 1. Vacuum leaks?
My wife use the Trekker daily and she says that the slip is more noticable when the car turns right. I believe this is a sign of faulty transmission pump.
I'm planning to take to Ah Wah soon to get it checked. Just need some feedback on possible issue from sifus here.
FYI, I've sent the gear for overhaul last year. Barely touched 20K since the overhaul.
xamel1975
20
3,003
Why not go back to them first, since they overhaul it or you have bad experience with them so need second opinion?
No bad experience except they didn't/refuse to adjust my steering when they reassemble the gearbox :-).
Plus, their workshop moved to new location (Seremban/Semenyih - can't recall).
Anyway, I believe that the slipping is not the gear itself. There's no metal residue or burn marks when I changed the fluid last week.
Could vacuum leaks causes slipping? Is it possible the error in air/fuel ratio causes the ECU 'pening' and send in wrong signal to the gear - hence the slipping?
xamel1975
20
3,003
Update:
Wife called and said the car now jerking followed by engine dies.
biao
348
24
perak / ipoh
Hi,
wow...20K for overhaul the gearbox only? so expensive...
what the shop name?
here's the deal, i'm trickin' out my uncle's old skool beetle and i wanna get it lowered. are there any adjustables or lowering springs available for an old car like this in kch? thanx in advance...
