Need advice on brake kit
So how does the braking feel now, any significant improvement compared to your previous brake setup?
Last time my friend converted his Nissan Bluebird brakes to GTR ones, did not improve, in fact got worse, because vacuum servo cannot handle, until he added aftermarket (add on) vacuum servo
tonyparir
49
508
Honestly the past few months I was quite lazy and did not get the chance to do any testing wasn't able to compared. But i notice one difference at low speed around 60kmh i slammed the pedal and it did not took long before my car stopped
Does it come with bigger vacuum servo?
When i bought my car it comes with a 96 dc2r brake servo. Hope thats good enough
sweelt
Nov 6, 2016
2,306
248
i think i borrow this thread to ask. Keep playing in my mind.
I ask before about brake pads.
My case. Wira gsrt, no mods, stock (all disc brake, single port). Brake been bleed couple of times. After bleed feel much better.
Few weeks later, pressing the brake pedal. Back to same old feeling, not much braking power. Press 2-3 time only can feel the hard feeling. Brake pads not worn out. No hydraulic oil leaked.
Need advice. Problem at Brake hose ? Brake caliper becos single port ? Brake pads ? Brake servo ?
If you need to press 2 to 3 times to brakes to function properly, usually means got air bubble in the system and needs bleeding.
For better braking try changing the pads first. Try Trestor Blue Advantage pads, cheap and good bite, but a lot of dust......lol:biggrin:
Okay noted. Will keep that in mind... when i ask around, my friends told me can use ek9's servo but any other suggestion?
Before changing make sure the servo unit is bigger, but then also make sure got space for bigger unit to go it. Mine was transferred from half cut, unit is bigger and is double layer
sweelt
Nov 6, 2016
2,306
248
Rubber hose can have this effect ?:confused:
y2188
441
42
28
Does the brake pedal sink when you hold it there? If it does you might wanna have a look at your brake pump too the seals and all. If it doesn't probably like what sifu vr said, bubble inside. Just my 2cents. :burnout::burnout::burnout:
Normally if worn and pedals sinks, I rather change the pump. Most pumps nowadays are made of aluminum and they are soft and wears easily. The seals wears the pump wall will wear also. I did once changing the seals only lasted a few months.....lol
How the windscreen, yesterday got rain, right?
sweelt
Nov 6, 2016
2,306
248
Brake pedal din sink, just feel need to press further compare to after bleed.
Bleed couple of times previously. Wondering where the air come from.
Or pump itself suck air by little?
You just bleed or flush? I recommend you do a complete flush, means change the brake fluid completely. Also did you overheat your brakes at any time after the bleed?
im using stock 1.5 Wira (4g15) and planned to change brake system coz twin port disc brake looks nicer... hehe~ :proud:
i bought already whole set Evo disc brake including evo servo. Juz installed front twin port disc brake, rear havent since got issues on lack of certain parts.
After i installed it, my car felt very heavy.. feels like its so under power. To make it easier to understand... i drove my car at 3rd gear.. feels like at 5th gear. High loss on torque.:bawling:
Is it...
