Need advice on brake kit
mADmAN
1,840
547
I was told that 262mm can also fit work... Should i just go on with 262mm? or better get 282mm
the twinblocks were made for 282mm rotors...262 probably alot of custom shit going on.
theres a wilwwood meant to be PnP with 262mm though.
get the 282mm.. will have more surface area for bite and cooling.
sweelt
Nov 6, 2016
2,306
248
mind i slot in one questions about brake.
my wira run on 93t stock standard. halfcut come with 4 disc brake. Single port, if i not mistaken.
invest in good brake pad , is adequate ? since i not craving for bhp.
any brand recommended ?
thanks.
mADmAN
1,840
547
Cheap and good. But dust a lot only, but main thing safety mah......:driver:
Almost my whole gang on them now......hhahhahhahahha:biggrin:
have u used it in SIC before? how did they hold up?
where to buy n how much btw? and do they have for R33 calipers?
been hearing alot obout this pads... quite curious.
May not be good for all out SIC use, since these are performance pads for daily use. Maybe bro. Izso can comment more as he tried them in his hero before in SIC.
tonyparir
49
508
After few months searching, finally got my rotor, was lucky enough to find PMU 2 piece, was quite steep, the slotted is not that deep but didn't feel like waiting, God knows how much longer I'd have to wait if pass on this one, I had people giving me recommendations on buying an EK9 disc which was 5x114PCD and custom drill to 4x114PCD, but i was leaning more towards PNP. I least expect to find this at a workshop tuning my hondata lol.
I guess I'm done on this thread. Thanks for the kind advice these past few weeks/months.
Next on my to do list
1. replacing internal parts of my engine, likely valve seal, spring retainers or parts that requires replacement
or
2. Fixing all the small ciku problem such as honk, bonnet clip etc
or
3. Installing a rear strut bar or X bar where it latches on the adjustable pillowball
(in no order, will be based on budget)
g4i8y0t
1,216
330
683
Kedah
So how does the braking feel now, any significant improvement compared to your previous brake setup?
mugen full set exhaust for 4 door eg or ek rm1850 nego, fto carbon bonnet rm980, fto front n rear disc for wira rm950 nego more detail pls call 0129688886/ 0169233888
Flickr: dspecial_list's Photostream
