Ivan's AE101 Build Thread 4AGE BT 20V6Spd No 56K
JDM-EK-AE101
502
121
Caribbean
www.zerotohundred.com
Hey, just received your reply. Am not sure about the sensor for transmission maybe i can find out when i am more available.
But didn't you ordered Fujitsubo Giken header? those are oem installed.
No problem mate No rush...
No I still have the Stock from the Engine Swap at this moment. Looking for the HKS 4-4-1.
JDM-EK-AE101
502
121
Caribbean
New Gas Tank And Seals 2-26-14
KenDiriwan
1,283
225
kendiriwan.multiply.com
There is a concern with HKS 4-4-1, if you internal isn't strong enough to output power. You will suffer power loss due to a way larger diameter of the header than any other aftermarket one. Also it compatible issue if you plan to install Cusco 4point lower brace
JDM-EK-AE101
502
121
Caribbean
ohhh
I see...
wich models are the other good options for me?
JDM-EK-AE101
502
121
Caribbean
Gas Tank Coating 2-27-14
As It come...
Start applying the Coating...
Coated with rust inhibitor paint and Ready...
Lines and seals Installed...
KenDiriwan
1,283
225
ohhh
I see...
Depends on the planned performance. If internal remain stock, the 4-2-1 from Fujitsubo, Cusco quite sufficient. Anyway stock header has the best low range rpm torque.
No problem if wana stick with HKS, just go for high deg cams, forged rod and 82mm piston lol
JDM-EK-AE101
502
121
Caribbean
I saw 2 diferent models from Fujitsubo correct?
I have TODA Cam Gears, TODA Time Belt and Looking for (Tomei Pon Cams or Kelford Type A) Cams with Velocity Stacks.
JDM-EK-AE101
502
121
Caribbean
Gas Tank Exhaust HeatShield Installed 2-28-14
Installing the new Gas/Fuel Tank...
Gas/Fuel tank Installed and Exhaust Heat Shield Back in place...
KenDiriwan
1,283
225
The only model i know off is this
https://www.fujitsubo.co.jp/prods/detail/000000000000001295/00000000000000002851/00000197
Which i am using.
Those i afraid aren't suffice to output the potential of HKS 441. It is labeled R.O (Race Only) liked Buddy Club Spec 2. Well it will be reveal once you go to the dyno
JDM-EK-AE101
502
121
Caribbean
JDM-EK-AE101
502
121
Caribbean
I'll be looking for one of those...
Actually don't see often the R-SR, Apexi, Cusco Right? Only The HKS & FGK?
JDM-EK-AE101
502
121
Caribbean
SS Braided Brake Lines 3-9-14
Stainless Steel Front Brake Lines
Installed
Need Advise n Opinion For 4G93
Now i want very fast to get Out Meter.i already change lancer meter 180KM/H.
So all of u can help me to get best performance with my car.(wira sedan)
1- Should be i convert to 4G91 HEAD DOHC.
2- Still use SOHC but Port Polish,install H/CAM,Adjstable Cam Pully, n use 3 kaki EXEDY Clutch.
For your refrence..
-I use 4g91 gearbox with 8.5" clucth n cover clucth
-Zenden extractor,1 bullet,2" piping n straight pipe
-Standard air filter...
