SATRIA 1.6 - Seeking advices for TUNING & UPGRADES
#OGPIM
86
7
KUALA LUMPUR
Oh shit bro... Time for 93 block swap bro, the head no damage right? :burnout:
im gonna change everything. Gasket ko also.
Basically my mech will overhaul it.
I Did notice some prob when i first purchased the car.
It seems that it cant go beyond 140kmph at 3000rpm.
When i hit 4500rpm, it blew up.
LittleWhiteWagon
1,656
187
P.J
Now you are making me doubt whether should I even change the extractor since you say it is quite pointless. After reading what you write, it looks like 4-2-1 is the better choice than 4-1 then?
By the way, what is the material for stock extractor? Mine now is like rusted all the way.
It is stuck after I brought it for a check with my mechanic. Flushed the radiator later and everything solved. But still, the water inside the radiator is still brownish even after flushing.
I think you're misunderstanding me, I didn't say pointless, I said at this point in time with your 110% stock engine, it'll suit a 4-2-1 design better than 4-1. It's up to you at the end of the day. I don't know what you plan to do with your car & engine in the long run...
Another thing you should know, an extractor swap regardless a 4-1 or 4-2-1 doesn't mean your car's powerband is going to dramatically change with either, and neither is your powerband going to dip so sharply that you'll feel a massive difference.
Btw you can get straight through mufflers that are quiet... just go get the largest longest straight flow muffler you can find and 2 large bullets/midbox I can guarantee the car will be quiet.
It's cast iron. Surface rust I assume?
LittleWhiteWagon
1,656
187
P.J
Looks like I shall ignore 4-1 then. I want to ask, after 4-2-1 is installed, I know it helps in lower to mid rpm range, but then how about high rpm like around 5k to 6k? Will the power at least remain as good as stock or even worse than stock?
I do like the feeling that the car gives when it goes over 5k rpm. :biggrin:
What kind of aftermarket extractor gives you worse power than a stock exhaust manifold wei? :stupid:
LittleWhiteWagon
1,656
187
P.J
Ok bro. 93 block yeah :driver:
Hi all sifu sifu here!
Want to ask about the ACR30 spoiler`s 3rd LED brake lamp... Where can i buy this part? Coz recently my Estima`s brake lamp got problem. I thought it was the wiring problem. But i`ve checked and checked again. It was not the wiring problem. Without the 3rd brake light it is very dangerous if i did brake and ppl could not know i was braking! In the worst case scenario if accident has to happen `bout ppl kissing my car`s butt then i will be one who is wrong! Please...
