Fake Iridium Spark Plugs
mnymy
Jul 2, 2012
25
7
503
Hai, have anyone came across fake Denso or NGK Iridium spark plugs?
Mine bought new 2 weeks ago, broken to two pieces during fittings and the tip melted after 2 weeks running. Almost cost me an overhaul..never happen before using both brands..last time bought cheap.:mad:
No wonder bro. TitanRev that day mentioned his Iridium melted. I told him in my turbo 2 sets also no melting....
mag9556
2,770
43
1,648
thats scary man...
never check my plug before.. later go back need to check already..
How much did you buy them? Please share the seller details clearly here so we can all avoid!
Nowadays many other parts like that. Even my mechanic also kena, for him he has to repurchase and redo for his client therefore becomes a loss to him. Of course for parts he can still claim from spare part shop but labor still loss....
ahming888
2
SIBU/SARAWAK
Fake denso and NGK iridium is very common since i 1st time buying iridium spark plug during 7 years ago. It is too common and hard to distinguish fake and genuine. Only few post with pics got discussion on that topic
Sent from my D6633 using Tapatalk
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Mine lasted longer than TS. Only 1 plug tip melted. Lucky nothing broken.
As I mentioned to you earlier, if original the Iridium should not melt. Probably the welding to hold the iridium tip melted or is fake......lol:driver:
KeeSeong
78
508
Mind to ask all sifus, how to actually see when the spark plug needed a change?? Is it the engine will vibrate or couldn't start at all????
Normally how long the life span of the spark plug? 2years??
Depends on what plugs also, best is go by mileage. If normal plugs can see the middle electrode worn round can change already. Platinum and Iridium the tip is so small and it hardly wear, so go by mileage is best....
KeeSeong
78
508
Oiccc.. Normally how much mileage it can go?? 30k km??
If the plug is already fouling then you'd have misfiring, like engine coughing/jerking/vibrating.
Normal plugs around can reach 30k km.
Iridium plugs can reach 100k km.
i just had my battery relocated to the trunk and i could not be sure whether this had caused me electrical unstablity because im noticing small bouncing rpm when signal light is on during idle, the vacuum meter dims when headlight and signal is switched on
my car is not super audio equipped, only brighter PIAA headlamp, and the meter. i have 2 stabilizers and problem still persists
i just talked to a friend who told me i need to get a grounding wire from alternator all the way to...
