Mazda 2 : what is the suitable engine oil
jedi
108
4
3,018
Hello,
As we know, when we bring our Mazda to Bermaz and they will use Shell lubricants, either Ultra or HX7 but these 2 are 5W40 and 10W40
I remember I read somewhere that Mazda 2 should use 5W30 and not 5W40, unfortunately this information was not available in Malaysia Mazda 2 owner manual.
Does anyone know anything about this ?
Thank you.
Hello,
Thank you.
The thing is when you send back to SC for service can you use your own oil?
Where did you read Mazda 2 using 5w-30?
ken yeang
6,617
1,327
Why go experimenting and listening to other source about which oil to use?
The oil type is already recommended by the Malaysia SC. Even the owner's manual would state the engine oil type.
Unless Mazda SC is secretly scheming all owners and recommended an inferior oil type....
ken yeang
6,617
1,327
hmmmm, secret oil from Mazda maybe?
Even my Toyota SEG's owner manual (20+ years) indicates the type of fluids to use for engine oil, brake oil, steering oil, coolant...Of course, the car engine so old oredi, I had to pandai pandai select a thicker engine oil...
After warranty anything goes loh! My wife's SUV sent to SC, can use their oil only. Now after warranty service outside use what I want.....hahahaha
Back to TS Mazda 2, most SC don't allow outside oil in case any warranty claim.....:rolleyes:
ken yeang
6,617
1,327
yeah, they want to protect their own business....That is why there are soooo many Cs in the service center these days.
More service they provide, more they can charge their customers....
jedi
108
4
3,018
the owner manual provided by mazda malaysia does not specifically says which viscosity is suitable.
In fact they gave the whole viscosity chart only.
I am referring to mazda thailand owner manual because i think malaysia and thailand has similar climate, should be ok. I know Mazda USA says we should use 5w20 but i think this is not suitable for malaysia.
---------- Post added at 10:11 AM ---------- 6 hour anti-bump limit - Previous post was at 10:07 AM ----------
5W30 and 5W40 isn't that far off la. Either one will do.
dude, i think it's totally different.
30 and 40 is the viscosity when the engine heats up. If the engine should use 5w30 but we used 5w40 then the engine oil might be too "thick" to reach every part in the engine, and the engine will be very "heavy" too....
ken yeang
6,617
1,327
Modern engine oil is designed to be usable and tolerant under a range of engine temperature.
Unless your car is a supercar, F1, Top-fuel car, etc....that rely heavily on peak performance......yes, specific oil is required.
But for everyday driving, then "close enough" engine oil grade is good enough.
Even mineral engine oil is good for daily driving....
Follow chart also wrong. 5w-30 from -30 deg C to 15 deg C only?
ken yeang
6,617
1,327
Hmmm.....the temp range (degree) indicated based on the oil viscosity in lab environment ka?
ken yeang
6,617
1,327
if ambient temp, this means the viscosity numbers are good for cold engine start-up.
Hello ZTH sifu,
Need help about FRP
My brother recently swap to another turbo on his L2S.
During the conversion, install a FRP and Fuel pump (Supra pump).
The weird thing is, the FRP is not install at the old FRP on the fuel rail.
If install at the usual place, the fuel filter will shake. (The turbo installer said that)
If I'm not mistaken, right now is
Pump > Filter > FRP > T joint
At the T join, one go to fuel rail, the other go to tank.
When to do a top overhaul at another...
