Where to custom piston and con rods
yewly1990
156
28
Any way to get custom piston in Malaysia?
Some tell me to email to oversea company to order, but who and which company.
Izzit possible to get it done in malaysia
yewly1990
156
28
u want customade pistons for your almera? I don't think its worth it. just do port & polish enuf.
Agreed, I know it not really worth, just wanna check do anywhere can get this kind of service, lower compression much suitable for turbo, should be last longer, just my 2 cent. Or incase if my stock broke down I able to get one.
I do have other car to play with, but hope to complete thus one first, and stop.
---------- Post added at 11:14 AM ---------- 6 hour anti-bump limit - Previous post was at 11:11 AM ----------
Find interchangeable pistons. I know someone like Izso did it with kembara piston on his 4G15. I think.
Ya, was planning to do so, If interchange, means I need to look for same cc car?
Lets say, if I have a engine kosong, so I just need to look for piston that could fit in with lower compression?
DanzEterna
15,911
3,371
www.primeperdanaclub.com
do like wat SC claims, use lower compression pistons from other cars but u need to do a lot of research on whether is the piston durable or not, if not end up blowing your engine.
yewly1990
156
28
I'm just running 0.6, dint plan to go high with it, its just daily driving car.
Seldom rev hard too, driving with monitoring boost meter.
TQ for the idea, will try looking for it at other car.
Rafale
73
7
1,508
Selangor KLIA
HR15DE: Bore : 78.0 mm (3.07 in) ; Stroke 78.4 mm (3.09 in) ; Capacity : 1498 cc
Like other suggestions, try looking for 78mm piston size with lower compression from other engine model.
Some engines that can use 78mm piston: Campro (oversize 2mm), 4g91, RB20
Ya, agree with it, after market are better.
But bad thing was, i'm only driving an almera, I cant find any after market con rods and piston for my hr15de in local yet.
That is the problem when you mod a common car that is not used for modding.....:smokin:
mADmAN
1,840
547
0.6 only ah? and seldom rev hard? no real need to spend on custom pistons.. stock pistons will hold up well enough... maybe add a thicker or another layer head gasket to bring the compression down abit.
unless u wanna start boosting above 1 bar then yeah, ull definitely need forged pistons.
hello, my car is 4G15 wira se 1.5 manual.. first i change the air filter to drop-in k&N. fc is quite the same unless i rev the engine, i think tht is normal due to more air being sucked in. so no problem. then, change to Denso iridium IW16 bought from tctho. aiyaa... the very first time i try the plug already sucked my petrol like vampire... very scared to push the pedal. my fc usually RM10 for 70km, now drop to about 35-45km for RM10. I drive my car to work, always traffic jam MRR2. even...
