DIY - Cooler AirCon for FREE
cvkit17
2,884
1,354
Good article but to layman like use still understand slightly only.....:biggrin:
Haha..very simple. The enthalpy is energy (which is the x-axis in the graph). So if heat goes into the refrigerant in the evaporator, enthalpy is increased. We call it superheat. At condenser side we call it sub cooling (reject heat).
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
so that means, insulate the line going to compressor is better coz reducing the risk of overheating the compressor for better performance, so the best way to improve performance of our AC is to insulate all so it runs under its circulation temp with lesser interference from outer temp. correct me if i am wrong sifuses
wifey lenovo wit tapatalk
cvkit17
2,884
1,354
You hit the spot! But insulating cold side has more effect than insulating the hot side
Supra_Fanatics
20,673
3,998
Like Vr2turbo told me yesterday. If the hot pipe is hot enough best to leave it. Unless is not hot enough the insulaflex will help. Cuz if it is very hot, if insulate, the temp would be trap inside and containing the heat inside and the heat cant disperse easily if were to compared with hot pipe unwrap right?
cvkit17
2,884
1,354
fark.. so do I wrap everything or not?
Wrap the suction line first.. Then if got extra, wrap the suction line of your other cars. If after that you still have extra then only wrap the hot line. No harm wrapping the hot line, just that it is not as good as wrapping the cold line.
But after wrapping and not enough you know who to look for......hahahhahahahhaha:rofl:
Supra_Fanatics
20,673
3,998
Mine 1 piece enough for 1 Kelisa and Kancil :biggrin:
Anyway, sharing my part. Mind the poor quality of photos...Cartel phones is not much to offer.
This was easier to be done, compared to my mousedeer which the cold pipeline is just too close to the chassis wall. Struggled longer than having it installed in my kelisa. Photos are kelisa.
cvkit17
2,884
1,354
Sorceryyyy~ wahaha
Some cars are very difficult to install this, like FD. The suction line is deep inside near to the firewall
Supra_Fanatics
20,673
3,998
Sorceryyyy~ wahaha
Ya sorcery, mira slightly more responsive after that :rofl:
Sorceryyyy~ wahaha
VR and Hyundai same, behind engine close to firewall. Hyundai may have some room but VR really tight space....But suction pipe very short only. Out firewall and reach compressor already as it is located near firewall....
mosesmk
165
32
Selangor
I just add another fan for cooling system. Got 3 fan under hood now. working good so far. cooler a/c and engine temp.
same as mine... :biggrin: :driver:
2 main fan running for radiator...
another one in front of a/c condenser coil.....
if a/c not on...during rising radiator temp, only 2 fan will be running.....
if a/c compressor kick in, all 3 fan will be running.....so now even in hot sunny day stuck in traffic jam also no worries a/c not cool enough :rofl:
helo there
im using wira 4g15 manual trans with weber dcnf 40 carb + knn air filter, powerzone cam, and powerzone 421 extractor
i need advise for the right/optimum piping size
rite now im using 2' piping, original route + 2' straight flow muffler
very hard to achieve top speed
rpm at about 5k something goes wrong
the car wont increase speed
feel like choked
have to release pedal little bit then press again then ok sikit
but then
its sucks
any opinion to increase the...
