naqi
wrap the whole car even better!fark.. so do I wrap everything or not?
Or touch and is cold.......hhahhahahhaDei, after a round of driving, u can see condensed water on one of the tubes.
In this case, follow the fat thingy.
Bro. dkny,Can anyone share me where to Wrap Myvi Lagi Best
Unless it is a few layer. Anyway this tube easier, just cut the length, cut the side and slip the tube in then cable tie it.Is it possible to use aluminum foil? Has anyone try it?
Hard to find. The last one i had from CVkit, it wasnt the right size. So after a while, the tube open up, leaving the aircon tube expose....Anyone knows where got shop or aircon shop that sells this?Unless it is a few layer. Anyway this tube easier, just cut the length, cut the side and slip the tube in then cable tie it.
foil doesn't 'hold' coldIs it possible to use aluminum foil? Has anyone try it?
goto home aircond installer..they probably give you for free....thats how i got mine :pHard to find. The last one i had from CVkit, it wasnt the right size. So after a while, the tube open up, leaving the aircon tube expose....Anyone knows where got shop or aircon shop that sells this?
Not the right size? You wrap the aluminum hose or rubber hose? For Aluminum just nice, rubber hose no need wrap...Hard to find. The last one i had from CVkit, it wasnt the right size. So after a while, the tube open up, leaving the aircon tube expose....Anyone knows where got shop or aircon shop that sells this?
Those we are using are for house air con ones......lolgoto home aircond installer..they probably give you for free....thats how i got mine :p
