Perdana V6 Community Forum *
kurt_629
872
54
johor
LOL, I came down from UDM to Perdana. By the way any TTs for Perdana in Damansara area? Just want to have my perdana done up nicely, hence am searching for parts here and there. Would need guidance from sifus here too.:adore:
Yeah, I believe they do.
Just that I never attend before.. working most of the time.by the way, your perdana ABS OK? You happen to know the part number?
wsonny
467
14
5,018
Ampang
Me too from UDM come down to perdana, I think part are almost the same price like my old ride.
wsonny
467
14
5,018
Ampang
u were using e46 before this right? no actually, perdana parts are very much cheaper compared to UDM's.
Mayb I been slaughter by workshop... Hehe
Any way now my ride giving me hard time, after change the mounting the weird cranking sound come out. Some of them said is the gearbox sound. When ever I throttle at gear 1, 2 & 3 the sound is there until the speed pick up the sound gone.... Is there any possible tat if my 4wd manual GB had been done by locking it and if the welding seal is broken it might had the sound come out from gb?
wsonny
467
14
5,018
Ampang
if your welding breaks your whole gbox cannot be used. if grinding sound means the bearing is worn out.
any difficulties in changing gears?
I had change my right hand side bearing and change gear oil also.... Danz let meet up sometime when free to for TT.
wsonny
467
14
5,018
Ampang
Finally get the GB taken out to change clutch, and found out serious oil leak. Hav to change all the oil seal inside the gear box. Cost me RM600 and half cut condition 9" clutch cost me RM400. Haiz.... Pok Kai already after had this car not for long... Still a long list to go
DanzEterna
15,911
3,371
www.primeperdanaclub.com
I bought new exedy 9" clutch for rm380. can be used but will slip on boost exceeding 0.8bar.
wsonny
467
14
5,018
Ampang
The old one also exedy 9" clutch use not more then 3 months it burn out. Can't hold if the boost on 0.9bar. Now I'm using GSR turbo 9" so far still ok as after I install I travel down to JB no more clutch slip.
humongousgravy
189
Seremban
Hi guys, ever since my car overheat there has been a sharp increase in FC. From 10-11 litres/km to now 13-14litres/km for city drive. Changed the radiator, water pump and the ss pipe (for thermostat?) since that overheating incident.
Any ideas? Spark plug was changed few months ago, maybe the cable? Engine and atf oil changed on time, can it be only the AFR?
Check if it is consuming water. Maybe header is warp and got some internal leakage?
humongousgravy
189
Seremban
So far have been checking radiator levels frequently, no water level drops yet. However I do noticed that the water hose is now fully kemek, until I open the radiator cap. Any problem with that? Or it just means my radiator is doing its job?
YYC
1,833
939
Collapsed water hose because the are vacuum in the cooling system.
Related to it, after flushing the radiator, should I let the engine runs for a period of time with radiator uncapped in order for the air bubbles in the cooling system to escape? How will the air bubbles affect the cooling?
Trapped air can cause radiator system to heat up.
Either it can escape through the expansion bottle or you can bleed it or you can leave the cap off until the water circulates...:driver:
DanzEterna
15,911
3,371
yes its true, last time I flushed my radiator system & took it out for a test drive as I was in a hurry, a few mins later my water temp shot to the red line, has to stop for a while let it cool down & drive it back home. had to drain the radiator again & finally it was all ok. the problem was air bubbles trapped inside the radiator.
YYC
1,833
939
Thank you for the explanation.
No wonder my car's temp went havoc for no reason the other day. Scratched my head until botak also couldn't find the problem. I didn't know that.
I normally let the system run for a while, then top up full, cap up then fill expansion bottle up too. After a drive and after the engine have cooled just check radiator water again and then check expansion bottle. Expansion bottle should go down slightly as after radiator is cooled it should have sucked some water from the expansion bottle....:driver:
marsha1l_v6
666
130
543
Hi guys...
any recommended adjustable suspension to replace my stock kong susp. planning to buy hwl around rm1790 siap pasang..
evo3
1,794
24
hi guy, need some help here. After changing my v6 front lower arm and do wheel alignment, the steering will not align itself back after turning. Anyone face this problem before? thanks
hye again, does any1 know or experience the zerone adjustable suspension,
does it to bumpy? or just nice? actually, im planing to buy soon, i really need ur advice?
prefer hi,lo,so,hard........ my budget is around rm2k.
pls advice,tq.
