YRV Engine
RENESIS VIII
7,063
950
Ipoh
Morning all..so that means we cant rojak the YRV engine with Ori myvi manual gear box right...so if using Tiptronic auto gear if we always shift to manual mood izit will make the AT die off faster?2nd question is izit possible to fix the YRV dashboard in to myvi?
Using manual mode won't affect the gearbox but it will probably affect your fuel consumption. Depending on how you drive. YRV dashboard is possible. The gear lever is located near the steering there. Somewhere near the wiper switch.
Supra_Fanatics
20,673
3,998
Change front halfcut with the gear, dashboards and engine. Settle. Manual Gearbox have to go.
et5828
1,848
5
Guys, Just to share. I owned a Kelisa with K3-ve2 engine before and with manual transmission, it gave me the best experience of my life.
Check out the video that i posted sometime ago. For memories :):):)
k3-ve2 20-100km in 6 sec - YouTube
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
hi guys. i didn't have much experience with YRV but my old mechanic at meru transplant it ALOT.. i notice that YRV K3vet is only come in automatic. But K3vet from Boon X4 is manual but yet cost like hell and it is so rare to find. U can match a YRV with ur myvi manual GB. it wont break but makesure u used performance clutch kit and it will fly like rocket. U can even turbocharged ur myvi engine but u must makesure u do the calculation to withstand certain amount of boost. but if u only running low boost, i think stock internal can run well only makesure u tune it well and the air fuel ratio is not too lean or too much rich..
or u can also transplant blacktop engine or starlet turbo engine as other option... TQ :driver:
Supra_Fanatics
20,673
3,998
That's real fast but I hear some tyre screeching? Can't test from 0km/h cuz wheel spin? :biggrin:
But K3VE2 the parts are hard to source. K3VE or k3VET more common no?
Then I think by putting a 1.3 Myvi engine in a Kelisa is also powerful enough :top:
Not sure if they have the Mirage 1.2L half cut already or not :biggrin:
Might have better FC in Kelisa :smile:
---------- Post added at 11:08 AM ---------- 6 hour anti-bump limit - Previous post was at 11:07 AM ----------
If can get BOON X4 half cut would be perfect. Since it comes with Manual, but not easy to find
like u said.
Too bad they din't made any manual transmission to pair with K3-VET. But there is something called Daihatsu Boon X4 which uses a turbocharged engine with manual transmission if I am not mistaken. Possible to get that halfcut over here?
k3-vet manual can be matched from 2nz gearbox (vios) :biggrin:
et5828
1,848
5
Might have better FC in Kelisa :smile:=
I took our the whole engine and checked everything before. The only difference is the piston and ecu. It is capable to rev up to 7.8k rpm. Normal myvi should be 6.8k rpm. In fact, i changed my gearbox with myvi before coz i smashed the gearbox at high rev:embarassed:
About my FC. it was awesomely good. I rev like @$%@$#% everyday also can get at least 400km for rm60. But the clutch always worn less than 10 months:banghead:
Supra_Fanatics
20,673
3,998
Any way to solve the clutch problem lke upgrading and etcs?
Not bad, my kelisa 411KM for RM55 but not really revving also :rofl:
Supra_Fanatics
20,673
3,998
vios has a manual GB? :hmmmm:
Almost clicked on dislike :rofl:
Of course, Vios J Spec has Manual Version. But then u get the lowest spec if choose manual.
No TRD version and etcs.
RENESIS VIII
7,063
950
Ipoh
Eh really? Good news then.
like u said.
First time heard of K3-VE2. Can tell me the specs? I mean how different is it with the normal K3-VE?
By the way, the name BOON sounds so funny for a car. :rofl:
Got. 2nd generation Vios have manual GB. Lowest spec Vios. Vios J.
What is ironic is, the cheapest low spec Vios J manual is actually faster than the most expensive so called TRD Vios with 4 speed auto.
Walao, TRD with 4 speed auto. :congrats:
Must show this picture already.
jun_ng_1208
476
32
Cheras
AFAIK, there is a lot of K3VET owners with original Myvi GB, upgrading the clutch to those from Works/Triniti would be sufficient if you are not boosting really high, one of my mate uses OEM Exedy replacement clutch & it would slips if he boost above 0.7bar on stock K3VET engine...
Supra_Fanatics
20,673
3,998
Myvi is already using the normal K3-VE so K3VE2 is from another car but rare engine here.
K3-VE : 64kW(86hp)/6000 rpm, 116Nm/3200 rpm (Myvi)
K3-VE2 : 75kW(101hp)/7000 rpm, 120Nm/4400 rpm (Storia)
Source from here :biggrin:
K3VET, K3VE2 & 4E Talks (Conversion, question, pricing, etc)
RENESIS VIII
7,063
950
Ipoh
That means can't really do much with the K3-VET then. Must stick to the stock 130hp if want to play manual transmission.
101hp sounds like a more decent output for the engine. But torque is just slightly more only.
The Marketplace Top Posts
WKC 727 stolen this morning @ sunway, parked near sunway college's side exit.
please if anyone seen a crx that resemble this (now the front n' rear bumper is WHITE!!), pls contact Eric 012 2070835.
thanks ZTH members!!
