JZ users thread (1JZ, 1.5JZ, 2JZ)
mafia1980
53
looking for r154 manual tranny ... pls pm me..:confused: ---already found de..
ahle@
1,102
12
malaysia
hi all sifu,do u know where can i get the 1jzgte vvti timing belt set and cam cover seal?
a lot spare part shop is selling the 1jzge set only.
here the item code:
Cambelt/timing belt - 13568-49065
idler sub-assy : Tensioner - 13505-46070
Hydraulic Tensioner - 13540-46030
cylinder head /cam cover seal : 11213-88410,11241-88410
washer seal: 90210-07001
Jet78
35
does anyone have a R154 Quick shifter for sale? please PM me... cheers
ahle@
1,102
12
malaysia
(WTS)1jz vvti turbo halfcut(auto),last batch model from toyota crown,better power then JZX100.
RM 4800,location puchong.
perthbrat
Oct 3, 2012
27
503
Guys, I'm searching for a MK4 supra TT 6spd manual. Have been looking everywhere. Mudah, zth, google, etc... All sold :(
Any of you guys know a supra for sale currently? Really want a TT 6spd hahah.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Currently an owner of two 1JZ-GTE both with single turbo. One 1JZ-GTE swapped in Rx-7 with R154 gear and exedy twin plate. Turbo Holset HX-40 almost equivalent to GT40R. 650CC injectors, HKS Fuel Cut Defender, Piggybacked with Apexi Vafc 2, Apexi AVCR boost Controller, running 1.8Bar on stock internals. Please don't ask for dyno reports as we don't have any dyno here in Pakistan :(. Another is Nissan Cedric old car currently going through swap with 1JZ-GTE W58 gear. Turbo Holset HX-35. 550CC injectors, HKS Fuel Cut Defender, Piggybacked with Apexi Safc 1, Turbo smart manual boost controller, will also run 1.8Bar on stock internal. And yes 1JZ-GTE can support 1.8Bar on stock internal. For drag races also tested 2.2Bar on stock internal. Then back to 1.8Bar, and engine is still safe and sound.
---------- Post added at 04:57 AM ---------- 6 hour anti-bump limit - Previous post was at 04:54 AM ----------
Saluran ahmedshaikhani - YouTube
Here is the video of my RX-7 with an AFR of 10 something. Running 1.2Bar boost. Had to hit rev limits because of traction issues. I was using normal street tyres.
---------- Post added at 05:08 AM ---------- 6 hour anti-bump limit - Previous post was at 04:57 AM ----------
Can't upload pictures of my Nissan Cedric don't know what's the issue. Currently car going through a process of fabrication.
Nice sound bro.
hasranizam
30
2
1,508
Dubai
Hello guys, i have one 1jz engine lantai (excluding ecu and trigger) c/w manual r154 for sale or swap with jzz30 engine and gb.. Please contact me 0163657036 hasra.. Thanks all.
nashlovebrown
2,245
16
kl
Hi bro ... Just want to get some information ... OEM conrod for 2JZ can go up to how many hp ?
Just bought supra n now overhauling , changing new OEM piston n thinking should I change to performance conrod ... Planning for 450hp to 500hp ... Need some advice ... Thx bross ...
speed44
1,782
10
5,138
Is still available ? where to view ?
The Marketplace Top Posts
all the masters of turbo....bro which engine is better ,more reliable...and more powerfulll....and i also want to lnow bout the mivec turbo..does it overtake all the bth engine mentioned aboved...performance and reliability wise...iam a newbie...hehehehe..thanks
