hi bro, what is the latest hwp after overhauled? using single turbo?Thanks alot bro .. Tomm buying 87mm piston n hoping for some good performance with emanage ultimate ;)
i have the same problem with my vvti. started around 6 months ago also. every time boost starts it's like no fuel going into the engine, felt like turbo just jammed when turbo begins to spool, sometimes can boost sometimes can't. now still checking it.Hi to all jz sifus here. Just need to know if our sifus here willing to hep me out from this problem. My problem starts around 6 months ago and here is my story.
I decided to convert my car's engine to the infamous 1jz- gte vvti taken from chaser half cut which I did. Everything seems to be normal at first but recently the engine started to show it's tantrums, the obvious is the engine shudders quite bad following the 'gila' rpm issues, at idle it will hover around 1k to 2k rpm and the brake will ' not makan' will accompanied that symptom. During driving the engine sounds like it struggle itself to go, sluggish, turbo will only open at 3k rpm which not like usual 2.4k rpm. The sounds of engine like fuel cut after a few seconds after turbo open.
So I sent this car to my mech, so he assumed the injector is the culprit but sadly it is not. Then we started changing vital parts like coil pack, throttle body, manifold sensor and air flow sensor but only to no avail.
I appreciate any comments and suggestions to solve this problem. Or where is your recommended workshops for this kind of issues. My mech gave up but he suggested in changing the vvti system parts . What is the relation to my problem, I also don't know.
Thanks for reading. Pardon my english..he he.
my mechanic no time to check everything yet, so far only basic stuff like air intake, petrol pump, filters and spark plugs were checked and they all looked fine. if drive without pushing the pedal hard, it's ok, no boost, no problem, going uphill also ok because got lots of low down torque, just can't boost. if WOT the engine will missfire like hell all the way to the red line.Thanks Bro Storm LCC for your comment. So what measures so far you have taken. How about your ride condition right now. Is it still driveable.?
In my case I drove to Cherating from K.L with that problem. It was not fun at all when the time you have to slow your car, it will shudder like those bulldozers or tractors.
Forgot to mention that we have changed it's ecu as well. For info, this problem occurs during drving and at idle as well. Anybody here can supply me with the contact number or the address of the workshop.
where is the timing sensor located?try the ignition / timing sensors..sometimes when d car is not pushed.. it's ok.. when it's pushed.. if it's cracked.. it goes out of position... unable to read timing bla bla bla. then misfire
thanks mate. i assume u r quite familiar with the engine? u r a mechanic right?
lol. understood. u still driving your orange supra?My belly is too big to be a mechanic. If I was a mechanic, I would be stuck under a car.. and would not be noticed until i've died and emit stench to the surrounding. ..If i was a mechanic, I wouldnt be able to reach the plug coils of a 2JZ or 1JZ whether I'm standing in the front, or accessing it from the side fenders... Sorry mate... I aint a mech.. but I know abit about cars
how about anyone in your area? KL / PJ? I'm sure u know some experienced mechanicsstormlcc - not anyone in Ipoh.
Yeah... i still have my Supra... but x drive it as much as i could
Yeah.. or maybe we can start a list of workshops that 'knows' this engine.. especially in KL or Selangor area.how about anyone in your area? KL / PJ? I'm sure u know some experienced mechanics
