y u wanna do that?
Why don't you create your own thread and ask the "Help me" question there. Don't hijack other peoples thread.hye, just bought cefiro rb20det, got problem, y my car semput, everytime tarik there alway a lag, sure got lag but this kind od lag when tekan pedal rasa kosong, pls help me
bro...pls create another thread regarding your issue. thanks.hye, just bought cefiro rb20det, got problem, y my car semput, everytime tarik there alway a lag, sure got lag but this kind od lag when tekan pedal rasa kosong, pls help me
Wanna mod from cable to clutch pump? Can. Pay the mechanic to do it for you. All the mounting points are the same except for the upper clutch pump, the mech will need to drill a hole in the firewall since you came from Auto.
U mean this??thanks for the reply here
after i survey about the clutch pump
and found that cannot settel the fire wall dent in problem
and the best way is to add a thick steel plate to the fire wall as base for the clutch cable
any one done this before???
can show some photo for me as my house got one Stainless steel plate about 3mm thick x 300mm length x 150mm width
i think is good enough for this
@Izso hi ... what if my car ori is manual ... now i just want to add clutch pump, is it plug and play? no need to drill any hole on firewall?Wanna mod from cable to clutch pump? Can. Pay the mechanic to do it for you. All the mounting points are the same except for the upper clutch pump, the mech will need to drill a hole in the firewall since you came from Auto.
Still need to, because your manual is now cable and need to secure the upper top pump...@Izso hi ... what if my car ori is manual ... now i just want to add clutch pump, is it plug and play? no need to drill any hole on firewall?
Thanks.
i see ... aiks ... is it my firewall still safe after manually drill it ?Still need to, because your manual is now cable and need to secure the upper top pump...
