Adding 2T as petrol additives...
nadziad - i've been using that all the while... but my regular supplier is not taking that in anymore as he says only a handful of customers buy FD as d rest buys FC... !@#!@#!@... ahahah... that one costs Rm29 compared to Motul's RM48..
for tcw3 2t oils u can search at motobike shop in chowkit road / sentul (NKS) / KLANG area..
-maxoil tcw3 outboards (pink-silver label) rm23
- pennzoil marine tcw3 outboards (yellow) rm25
- mag1 tcw3 outboards (black) rm21
- quicksilver tcw3 outboards (silver bottle) rm26
been using all these tcw3 into my retro 2stroke bike.. running well and very clean + smooth!
not yet try applying into my car.. (waja)
for jaso FD.. u can get repsol competicion fully sintetik rm75++..
repsol > MIBC Sportbike Forum - Repsol Competicion
Diesel car no comment bro because diesel fuel very oily but petrol car.:burnout:
Is similar to Morey upper cylinder lubricant which is oil also.....
MOREY’S UPPER CYLINDER LUBRICANT & INJECTOR CLEANER | Morey's Lubrication Systems
Then Marvel mystery oil....
::Marvel Mystery Oil::
and many others......:driver:
---------- Post added at 04:05 PM ---------- 6 hour anti-bump limit - Previous post was at 04:01 PM ----------
Guys, 2T in car petrol tank??
2T so oily can clean up injector meh??
i think will create more carbon later in the intake valve ..
i got use 2T empty bottle which got around 1% of 2T to fill up fuel then pour in motorcycle.
The result was smoother ride..
I have some members using moth balls in the petrol tank......:driver:
I'd personally like to try this. But I also need a way to verify what happens inside after a period of time of usage.
This would make for an interesting mythbuster discussion
This result is like after one or two years usage?
I was thinking short term - 6 months. I guess I'd need to open the cylinder head and do a top overhaul to see the effects?
Either start clean or like bro. BH scope now and then after 6 months.....
moth balls you guys talking is those round round ubat used as repellent for roaches, and insects?
put in clorox la. :P
Btw i did try to mix a few drops of 2t with petrol in my bike after topping it up... result = got alot of smoke behind at first. :P but abit smoother la. ABIT only. conclusion = wont do it again. lol. dont like my bike smoking that much. original amount of smoke also dont like adi.
2 stroke bike, maybe already 2T already tuned high.....
hehe...i never use 2t fd so i dont know about it...since i have survey that shell vsx is cost rm 25 and castrol 2t cost rm23. i think i may change to 2t fd next time...maybe mr blackhowling can try survey at bike shop that sell aftermarket part...ala racing2 part..hehe
---------- Post added at 06:19 PM ---------- 6 hour anti-bump limit - Previous post was at 06:08 PM ----------
i have try using these moth ball into my petrol tank.....not very recommended...these moth ball will make ur ride sluggish no power.... i have try put a moth ball into a glass of petrol and these moth ball will make some bubble like the panadol soluble..after a several time u will see some crystal like salt at the bottom of the glass... i think the salt crystal will blocking ur injectors or carburetors..
Before and after pictures of inside of the engine?
Fuel milage?
Er what else?
Dyno Before and After? :burnout:
Joking. :biggrin:
Would be awesome, if Izso do it. :adore:
Thanks for the feedback.....
---------- Post added at 09:44 PM ---------- 6 hour anti-bump limit - Previous post was at 09:43 PM ----------
Fuel milage?
Er what else?
Joking. :biggrin:
Bro. Izso test sure the feedback will be pretty awesome and complete....:driver:
wah.. pressure pressure. :biggrin:
Well, since I need to do a top overhaul anyway, I might as well try this! 2T here I come. I just hope it doesn't do anything to my overly sensitive engine.
Like blow up or something. Anyone got a torque wrench i could borrow?
Btw, don't simply buy any mothball and try. It has to be naphthalene based. Most modern mothballs these days don't use this flammable chemical anymore.
wanna buy JASO FD 2T FULLY SINTETIK.. DROP ME A PM.. HIHI.. BELOW RM45 1liter
Should sponsor some to bro. Izso for test.
Report comes out good, your sales will shoot up for sure......:driver:
---------- Post added at 02:05 PM ---------- 6 hour anti-bump limit - Previous post was at 02:03 PM ----------
So, if use naphthalene based, can try??
Its pretty common to see Mat salleh adding 2T as additives in their petrol/diesel tank (can do search from BITOG). They usually use TCW3 rated 2T since it is ashless and will not dirty up the combusion chamber..
2T Oils contain about 25% PolyIsoButylene (PIB), PIB changes the properties of fuel, resulting in uniformity of fuel molecules, hence total and uniform combustion.
Got this from most forum on adding 2T to petrol......got to try already....:driver:
