Putra turbo "Clearance Issue"-fabricate/custom-post ur pics here
virqai
206
393
1,563
update...hope enjoy..:burnout:
:vroam:
virqai
206
393
1,563
3 part weld to be one...after grind,sanding and minor polishing...
i'd like the spot turn to blue..but sometime can sometime not...:bawling:
virqai
206
393
1,563
Update..change pipe no 2 and 3...:biggrin:
Collector...:motz:
Fitting turbo flange....
punk
360
76
Negeri Sembilan
Hey bro, nice welding there..
my bro jus give me sample pipe that u use, very heavy man...
Any reason u use that thick pipe??is it because of high boost durability??
virqai
206
393
1,563
Ya..hey punk..thanks :thrasher:...i use 304 gred,3mm thick stn.stell..like usual other exs fabricator use..
nope.. its not to heavy for me..compare oem header...but for sure all depend for header design.if log type sure really light...more long,more material right...but u can just imagine if its cas iron, all runner 17"length(out side conner) x 4 =68"=5.6'...weight???
reason...need more hot and lasting from band,twist,crack(if wrap) when hot,can hold more turbo weight..
Hope other Sifu also can help to answer your question...:nurse:
iswara204
545
13
whoa!!! this is awesome work! and not mentioning, all the sweat and the brain drain! Kudos!! any final pic of the finish??
virqai
206
393
1,563
Final pics....still not in mode for that...heeeee....next..next..now just want to talk-talk here only:rofl:
hey all,
any good tool shops around leisure mall area that sell garage tools such as timing light, support jacks, hydraulic floor jack, etc.
around tmn midah, phoenix plaza, tmn len sen, leiure mall, tmn connought would be good. don't intend to travel far.
thanks. :)
pls provide a contact number and an address.
