Putra turbo "Clearance Issue"-fabricate/custom-post ur pics here
virqai
206
393
1,563
Is this what always happen when proton turbo go for big turbo and radiator....perggggh...this guys my friend,open his car hood, then till now i cant say anything...hope all sifu here can help..pics more help.
ha..ha..ha..ha
hu..hu..hu..hu
ho..ho.ho..ho
he..he..he..i keep thinking what special tool can open this filter...20pound hammer? a bit can say now
is this sensor just can simpley put after turbo like this...or have any any distance seat?
dont want thinkto much,i start to fabricate front frame..make its can open2 punya...huh tired,suffer
krem..kreem...kreeem:sleep:
virqai
206
393
1,563
this header to much crack..thin S.stell can't hold turbo weight.turbo hot side oso seat near to W.pump pipe and blok.not cooking ker..:questionmark:lazy to go cut new flange so i cut this flange to use back..centre its and make holder..
set at disk cutter and tap..to hold it proper when cut
no 3 done..now the last one...need some weight to twist this pipe when cut..
Kautim...k.i.v-...
Rainy stop so can make out door activity now..hoye..better make jig for front bar now..get centre mark and bend mark..
draw at floor to check left and right get same radius or not
lariiiii....
fix its..then ok...can see my hand turn to green when bend the steal :biggrin:
look and see...
add some more steal to strengthen,for i can keep its.
waahh..long time rest ha..tomorrow need your help...day turn dark now..
settle left side breket mount..
virqai
206
393
1,563
Use waja 1.8 oil filter can help u settle ur oil filter problem..
nice mod and nice sharing :)
T.q...i thinks its use already...so small oil filter there..cant pull out,so close with exos pipe...owner say before this need to open exos pipe for replace new...waalauwei..who wants to do thats...
---------- Post added at 05:28 AM ---------- 6 hour anti-bump limit - Previous post was at 04:39 AM ----------
Bent machine problem..after troubleshoot its from switch...gets its new and no time to put its proper,just like this for temporary
make a centre line...use paint maker
this why i need to draw centre line...both side bent must level
First bent done...need to mark mould turn and check pipe bent with jig..
Second bent...cant see there are white line at centre mould..its came from pipe line when first bent and stick there...easy..
turn till reach to first bent mark
done..ok la kot...:biggrin:
cut end pipe and test how its look...
And now most important thing to doooo isssss:sleep:
virqai
206
393
1,563
wahh, thumbs up!!
very big project!!
Not so big la Jakk...kg project only..:bawling:
Use 4.8mm for bar mounting...
Syiok kaa?
T.q for your weight Bib...
Roti canai... satuuu..... :pepsi:
virqai
206
393
1,563
thanks Danz for looking my built...come and share something....
Today try to settle centre top frame and bonnet lock...pics from other car for dummy...
Get centre line for top (lock) to bottom for breket link.
Spot weld breket for bonnet lock
Make frame link breket...
try fitting...
bera
822
229
1,543
fuh...that really is a lot of work...sallute...
basikal_pancit
603
54
3,028
Selangor
THIS THREAD IS WORTH READINGG!!!!!!!!!! THUMBS UP! This type of people will bring up the motorsport industry to another level :)
romen_
188
49
kl
A simple-in-theory mod, but takes a lot of hard work
congrats to your weight savings, less overheating issues and better structural rigidity!
ken yeang
6,000 RPM
6,617
1,327
Bro, I don't mean to be the rain in your parade, but this is considered as illegal mods....Anyway, as long as the owner happy, his money, his business.
virqai
206
393
1,563
people with ideas.
salute la bro...
:wavey:
TQ...all of u same laa...can see and have a brave to say like that...thats way we are here right?..:five::shakehands::beer::knuddel::rock:
virqai
206
393
1,563
yes u a right Bos..thats way till now we still need to tumpang soyuz to go space...right?:banghead::rock:
---------- Post added at 05:10 PM ---------- 6 hour anti-bump limit - Previous post was at 04:46 PM ----------
but im sure his mods are more sturdy than factory ones.
:idea::joyman::alberteinstein::knuddel: :thrasher::rock::beer::congrats::biggrin::adore: :star::top:
I'm looking for a lip for my air intake system.
Pls take a look at the attached pix below & kindly advice if there's a shop that could custom make the particular parts.
I don't really mind the what they use to make it as long that it's durable. Plastic, metal, rubber all accepted.
Preferring metal but those kind won't get rusted(painted black would do).
Heat resist is a must, I know that it's for cold air intake but when the car is parked, the inner heat is really hot.
Normal engine heat is...
