Keeping a white car WHITE!!!
kc2
1,354
1,410
thedetailers.blogspot.com
I have countless text, calls, email....asking
how do you keep your white car white? well it is not easy but truly rewarding
I used to use 99 soft but ended having hard muscle ache polishing wax, alot of effort to remove water / rubber stains......on the paint
begin with the most contaminated area of the car..... Wheels
closer
but now with the safest Multi purpose cleaner - so effective to degreaser and yet so gentle to be used on leather.....just dilutes according to your need.....
with the help of
I use 1:3 alien clean/water for rims (only uses 25% strength)
1:5 alien clean/water for painted area (17% strength)
lower area - is the last area you would like to wash (so pls begin with the right spot)
washing is always from TOP to bottom
tars stains - cos near G. election
lower
next moving to rear
look at the amount of contamination picked by the wheels!!!! esp asbestos from brakes & metal flakes from the rotor disc
remember - let the car cool down (best in the morning or evening)
start from top
Opti Mitt - my washing companion
ta da
sun shots
after travelling 350KM
who says hard
ta da
ta da
before
now
my cleaning buddy
protect with OID in just 5 minutes ( a prefect company for no rinse wash)
kc2
1,354
1,410
It's so easy effective and most of all another effortless car wash! Wipe on and rinse off in just less than half an hour
kc2
1,354
1,410
That's quite some detailing going on there..
The wheels changed from BBS to Lambo..
Wonder what it could do to the car..
:P
Hahahahahahahahahahpaha
U think I am david copper field ke!!!!!! Just an example of it
mc888
196
59
Little HK
Hi KC, i've OPC stains on my windscreen because it dries up faster than i thought. Any idea how to remove them?
Thanks.
ShowTime
88
77
Thanks.
To my personal experience, its best to use the LEAST aggressive method to get the job done. Try claying 1st using the least aggressive clay. Example PG PERMAGLASS CLAY number 1(blue) or number 2(green). If you have PG clay number 3(aggressive white clay) then use it after trying those least aggressive clays. If still doesn't work then its straight to polishing(least aggressive polish/All In One product). Try a test spot polish by hand 1st using an applicator pad or a soft sponge since glass is harder than paint.
Unless KC & other enthusiast have other trick in their bag. :smile:
kc2
1,354
1,410
Thanks.
It happen when u apply on hot surface ESP under sun
Try re OPc it and rinse off, repeat if must
kc2
1,354
1,410
a week later
ala- mek dirty again....cant help it ....we are in tropics........hot & wet & hot again then wet again
look at the amount of dirt (8 days almost 1000Km later)
more dirt picked (8 days almost 1000Km later)
and I can afford 2-4 hours just to wash this babe
so I decide to ANR my ride (alien no rinse wash) now in 20 minutes
How to ONR - soak in washing medium Opti mitt or MF
slowly glide from left to right ( wash begin from top of your car again) Sanitation
instantly dry with 2 MF
ta da
remember here
ANR wash it
ta da
before
after ANR it
ta da
just 20 minutes wash
another 5 minutes to top up my magnificent Protector (it also does help u to clean those parts of ANR maintenance wash missed) 2 in 1
the very next day
ta da
the key of maintenance is just my weekly wash & OID protecting it
in this case Less is More
Ok the situation now is , current Caliper Pistons seems to jammed one side alrdy , on the passenger side , and since the disc also can't be skimmed no more , i decided to change all 4 rotors , brake pads and service all the calipers ...
problem is i don't know what are the OEM brands for my rotors so i did a search ... in which i found a few brands which are
BOSCH(standard) - RM70/pc for front and RM60/pc for rear
TRW(standard) - RM110/pc for front and RM100/pc for rear
IMP...
