EG clubs/owner etc
ddv_nk12
1,228
236
PD
Ya ka?? If 1 level above Civic, I don't mind swap plus some cash. Hehe. But I usually see Civic's whacking my car most of the time. So much so, I see any Civic, ajak me, I just go to the left and drive slow. Lol.
ddv_nk12
1,228
236
PD
R is welcome too no prob for honda...:biggrin:
yours integra not same bro...Honda also....
aiya so hard...no ppl vote :banghead:
If R35 also can join this thread, then better change the title to ALL ZTH CAR OWNERS CLUB. Actually we don't even need this thread. We have an entire forum already.
peterj
1,321
258
1,683
Kuching
just let the name like that...
peterj
1,321
258
1,683
Kuching
sifu madman, now i installed the ASR, understand the concept of it, no nid drill, ori civic got all the holes, just honda use a metal plate and screw it to cover it, but i just realize and think that the ASR make the force disperse to the alloy bracket more then on the bling bling brace...lol
mADmAN
1,840
547
if u install the ARB, then the force of the ARB will be distributed around the brace before actually going to the bracket...
u installed ori or replica?
post picture laaaaaaaa
peterj
1,321
258
1,683
Kuching
i think is replica,i got it for rm300:biggrin: but replica not good enough?:confused:
note that i changed the lower arm bolt to longer 1 since added thickness (white circle),and i jack a bit the ARB bracket to fit cause my car so bad, the cross member ada lari sikit,so the holes not accurately in position....
take look at the picture, red circle, what i mean is the bracket (shiny alloy) is in between the car's cross member and the ASR brace, make me feel like the force more on the bracket and the ori cross member then on the brace.........it just like a washer in between the brace and the cross member.... lol
mADmAN
1,840
547
300 is replica... ori is RM9xx
and get rid of the UR tie bar la... already pasang the ASR, the tie bar becomes useless.... adds unnecessary weight really spoils the look
peterj
1,321
258
1,683
Kuching
u sure it become useless dy??:confused::confused: and , what big diff between ori and imitation?:confused: and bro madman u use ori?
arrowhead
4,621
152
5,163
Damansara/PJ
theory wise, both works the same. strengthening the same points, as they bolt the same points. but material of the two may be different?
again, theory wise, i think both has the same function... open for debate.. i am no engineer.
peterj
1,321
258
1,683
Kuching
my failing engineering theory is (i am just engineering student), more bar ,or thicker bar will make it strengthen more, does it will?? lol:biggrin::biggrin:
and for the weight issue, the ASR is twice or 3 times heavier then the UR bar since it is thick, i am not so worry of adding more weight at the rear since i removed spare tyre at the rear,lol
i am more worry on the diff between ori and imitation , and also the problem of the UR bar always hit by stone..lol
sifu madman pls comment:wavey:
---------- Post added at 10:44 PM ---------- 6 hour anti-bump limit - Previous post was at 10:41 PM ----------
and also, i agree the ASR will strengthen more then the UR since UR just 2 bolt at 2 point, but the ASR had 2 bolts each sides to hold together on the cross member and it is thicker and more surface covered
arrowhead
4,621
152
5,163
Damansara/PJ
ohhh shit, u asking abt the tie bar is it? i thought u were comparing the ori ASR subframe with the immitation one.
i THINK (not an engineer) what madman said its true, but what u said is also true. i had this discussiom with my foremen. he used the metal bar from inside an EG door, those "roll cage" type piping inside our doors, he cut it out and welded it to the chassis, below the ASR subframe, or rather, in between the subframe. i quote him "stiffer is of course better, but if its too stiff, he may suffer oversteer"
not my words. just quoting. open for discussion
peterj
1,321
258
1,683
Kuching
i am asking both the tie bar and the diff between ASR ori and imi... but from what i think, the imi might be same stiffness or weak a bit then the ori, sometimes, from what i compare the imi and ori stuff, for metal or alloy stuff, ori tend to have better performance and but lighter weight then imi since the material used is better and lighter,can see it from the price.....
currently not afraid of thos understeer or oversteer, cause my max speed now just 100km/h nia lol...:biggrin::biggrin: i am :slug: driver
just changed timing belt and those tear and wear parts, repaired water leak and some minor oil leak, waiting for better rubber to test d16 top speed:biggrin::biggrin: now not so dare to push it with cap ayam tyres...
---------- Post added at 11:03 PM ---------- 6 hour anti-bump limit - Previous post was at 11:02 PM ----------
and my car just with better pad in front,stock brake system without rear disc brake, not dare to push fast also..lol
Similar threads   Forum
DR78 General Talk
News and Features
ICE -In Car Entertainment
Wheel And Tyre
Car Talk
Car Detailing Forums
Honda
Looking For
Car Talk
  Similar Threads
DR78 General Talk
News and Features
Wheel And Tyre
Car Talk
Honda
Looking For
Car Talk
I don;t know how to explain,
Here my problem, I changed the aftermarket throttle body, then i realize my the throttle body which connected to TPS sensor rotate not as what it suppose to be.
Mean the rotation of throttle body not same as TPS sensor. Did you guys know whether
1) All TPS sensor rotate same way ( follow clock wise )
2) Or could I get another TPS sensor which rotate differance way( lawan arah jam )
anyway I'm using toyota 3sgte.
Anyone could advice me ..
It almost a...
