Steering Vibrate, on wheel balanced already..
arrowhead
4,621
152
5,163
Damansara/PJ
to all the sifu's, pls help me diagnose my problem.
i changed to a new set of wheels and right after that, i noticed my steering vibrates when i hit 120km. below that, its fine.
brought back to do "on-wheel" balancing, it didnt vibrate 1 bit. so the mechanic said, possible due to the rear, and then he went to balance my rear.
tested it on the hway, still vibrate @ about 120km/h.
problem is, sometimes it starts vibrating @ 100km/h - 120km/h, then it'll stop when i go over. the i slowed down, then brought it back up to 100km/h, no vibration.
wth? sekejap ada sekejap takda...
i've singled out these few potential probs, maybe u guys can add in so i can check
1. tire makan 1 side?
2. wheel/hub bearing?
3. c/v joint needs more grease?
4. lsd problem?
:confused:
thanks
jy_1990
25
I am having the same problem! but i guess it's because of the imperfect rims... can i know if your rims are new rims?
g4i8y0t
1,216
330
683
Kedah
I had the same problem too a few months ago. Problem solved when I change my steering rack and the front tyres (botak already).
arrowhead
4,621
152
5,163
Damansara/PJ
Rims are new. Not used.
Steering rack? My tuner said my steering lately got alot free play, possibly on the verge of dying.. Aiyoo. So many problems coming at the same time.
Thanks. Will get them checked.
arrowhead
4,621
152
5,163
Damansara/PJ
not so soon bro, probably will only visit my foremen next saturday, that is, if he is free to troubleshoot.. else i'll just drive @ 80km/h HAHAHAHA
last time i kena this because my tyre is cheap indo tyre where when thread almost botak the tyre wobble....ekekekek
but it might worth checking your tie rod also...
D7zul
2,697
848
Shah Alam
tie rod , driveshaft.. get it check
check those things..
if still vibrate, jack ur car & try shaking ur tyre.. u'll see which part is loose
:wink:
cacin
1,000
5
5,138
happens to me too, when go to the shop, it turns out the OEM rim bengkok. . .
most likely due to masuk lubang. . .
Rim was 17". forgot the tyre profile. . .
don't want to change rim yet, so had to use spare tyre, the worst case bengkok become spare tyre and the least bengkok one to the rear. . .
probably need to look for 16" rims la after this. . .
arrowhead
4,621
152
5,163
Damansara/PJ
im quite sure my rims are fine, just got new set. anyway, will update when i find out.. else, i might just leave it as i dont drive it often..
AD_EG
6,328
231
Ipoh
your rims replica or ori rims ?
can i actually know wat is the use of installing fibre hood???
is it can absorb heat?? or juz a decoration???
fibre is it very crispy??
thx for answering:adore: :adore:
