Need Sifus help on Upgrades for my Gsr
vishnuruben
From Facebook
Sep 25, 2010
14
www.facebook.com
Sifus,
I recently upgraded to stainless steel piping/walbro fuel pump however my actuator kong twice resulting over boost.Recently my con rod bengkok and piston damaged.
I am planning to upgrade to a tial original wastegate/banana 2mm and tomei fuel regulator.
Maintaining the turbine at td04.
Need your advise if this can permanently fix my overboost issues and if it does, is this enough for me to boost at 1bar w/out any problems.
Thanks
jinkl
4,624
376
3,183
Sifus,
Thanks
if i was u, i will stick to the stock manifold ported nicely for better flow , the stainless steel for a td04 flange would be a waste
plug the wastegate at the o2 housing and not the manifold
like these
vishnuruben
From Facebook
14
www.facebook.com
Bro thank you for replying..
Could you explain further 'i will stick to the stock manifold ported nicely for better flow' meaning to say u are suggesting not to fix the banana 2mm is it?
'plug the wastegate at the o2 housing and not the manifold
like these'...would the foreman know if i told him this?
xtremeleo
3,247
464
5,183
for a td04, fitting the wastegate dat way is better for zorst flow, and wont be as laggy as when u fit it on the zorst manifold/banana. plus, the std zorst manifold is good enough to take on the td04 at full boost, so an upgrade isnt really necessary, according to jinkl. iam with him in this subject matter sir
vishnuruben
From Facebook
14
www.facebook.com
Aiittt bro..
so meaning to say just the wastegate and the fuel regulator would be good enough?
How much could i boost with these upgrades, prioe to this i have installed metal gasket/walbro fuel pump and stainless steel piping..
whats the max i can boost and is it considered safe to boost in this high?
xtremeleo
3,247
464
5,183
1.2bar shud be fine imo, the engine/turbine can handle more, but needs different setup
vishnuruben
From Facebook
14
www.facebook.com
I also need an advise on the wastegate size that i should get as currently my turbo is lagging very badly and this occured after changing the stainless steel piping...
Please also advise how much would it cost to fix the wastegate,any suggestions on where i can send the car for the installation?
Appreciate ur help,thanks guys....
jinkl
4,624
376
3,183
no doubt its emanage , wastegate , fuel regulator,
the banana doesnt cause much effect to increase power or spool for a td04 or even a td05 , and the 2mm banana will crack in time no doubtly, believe me , i have been there :):) , get a good regulator if can buy original
the lag could be because of intercooler piping thts too big and also could be there your actuator is not closed properly, causing premature opening tht will lead to huge lag
vishnuruben
From Facebook
14
www.facebook.com
Bro i just saw ur reply..i got the original wastegate tial 38mm with tomei fuel regulator rm940 overall...is it a good buy?
Bought it from andy-rev performance..he differentiated the ori/replica and the diff was ori had 2 inlets and the replica had only 1
Correct me if i am wrong....
Thanks
xtremeleo
3,247
464
5,183
Thanks
sir, dont u think asking about this after u pruchased the items is a tad too late? shudnt u be asking these questions before paying for them?
i prefer the internal original wastegate btw:hmmmm:
Hye, i want to ask anyone who have experienced installed viva 1.0 manual gearbox into their kancil turbo. Currently im on L6 EF-RL engine with rfh4 turbo, 240 injector, adjustable fuel regulator, 2" straight piping, downpipe and emanage. Planning to upgrade the gearbox to viva 1.0 manual gearbox because the 660 gb like scream for another gear at the highway. Is the ratio for viva 1.0 gb is to large for my 660T kancil? Sorry for my bad english.
