New 17'' Rims
lilwhite
354
Whole of Jalan Kapar also can....compare prices......
will do that.....but pairing with what tyres will be the monst trust worthy, my budget for tyres is btween 300 to 400 each
Front: 205/45/17
Rear: 215/45/17
Are you running a RWD ride? If not, why smaller front tyres? Using different size tyres you would not be able to rotate your tyres and for FWD, the rears will last a long time, whereas the fronts will finish off very fast.
For tyres, GY Asy. can be consider in the RM400 range. Lower priced will be Nexen N8000, maybe Hankook V12Evo, Federal 595Evo or Maxxis i-pro, but performance for the later 4, may be slightly lower.
PS3, Toyo T-1R, Yoko S-Drive, Falken FK452 all will be expensive.
Maybe can look out for GY F1 Asy. 2, or GY F1-D5 that is just out.....
lilwhite
354
howbout brdgestone tyres???? any potenza series model that suits my requirement??
ehdrian
I Don't Care!
3,310
280
1,683
re001 is so so only..better get michelin ps3..
---------- Post added at 10:40 PM ---------- 6 hour anti-bump limit - Previous post was at 10:31 PM ----------
or eagle f1 asymmetric..
lilwhite
354
how much will that be per piece as the size i mentioned???
hi guys..i found this ad in mudah.my that can convert waja single cam to twin cam..is this possible?as i know,only 4G15 DOHC head can plonk into 4G18 engine..but,i've asked,and the head is from CK2A..
here's the ad..pls clarify..
http://www.mudah.my/Doing-WAJA-4G18-SOHC-convert-to-DOHC-5605055.htm
