hard to shift to 2nd gear
H22-C
642
74
i really dunno my motul grade, you can try to ask Ah Loy if you want.
clanzkiller
1,394
27
1,648
Hey bro, any solution or updates from it? I'm getting annoyed whenever the 2nd gear is hard to shift. Sometimes cannot shift at all and have to repress clutch only can engaged.
peterj
1,321
258
1,683
Kuching
looks like all car owner here are rich and using high end brand oil:adore: mine only using mitsu diaqueen lsd gear oil for front gearbox, mid and rear differential :bawling: no money, but shift is still ok, just 5th gear hard cause suspected syncrho gone...lol
clanzkiller
1,394
27
1,648
Waa bro, like that I also need to look for a new syncro
Meh? :(...
Just because of changing gear oil can cause so much prob... Btw now, my first gear sometimes wan to shift from 1st gear to free also got problem d even the clutch has been fully pressed. Is like I'm forcing to switch the gear. Dam
peterj
1,321
258
1,683
Kuching
synchro is the mechanism that match up ur gear speed in order to made a smooth shift, if synchro got problem, symptom probably like mine, when slow or low speed shift to 5th gear fast, smooth, but, if u rev high or change gear fast in a faster speed like over 80km/h to 5th gear, it can be shift but u will heard some kind of sound like "gruok" that will make u feel bei song, luckily it was no the gear grinding "krack" sound, synchro can be replace , do found out few service provider in zth, guys can search in zth.......
PabloIceman
3,083
291
1,683
Got a spare synchro with transfer case for CP9A ...
greenmivec
341
126
I think i am facing the same issue as well, I can feel my 2nd gear is a bit difficult to enggage it feels like gear tak masuk with a bit locking feel and some noise.
At first i think i did fully step on the clutch by i was wrong it happens a few times but sometimes it not happen.
Other gear no proble at all. I will check what gear oil i use. Anynsolution on this?change oil?what brand and price?
By the way i am driving evo ix.
greenmivec
341
126
Guys
Is it possible that the clutch need to be adjusted to remove the problem?
skyboy
699
34
KUL
Hi Guys , i got the same issue but this happen after my engine warm up.. the.. first 20 - 30 km the gear shift is smooth later i'll have problem shiftin 2nd and 3rd , I've change my clucth recently (3 months) , pls advice.
clanzkiller
1,394
27
1,648
Bro try to switch 1st-2nd gear in 2k rpm and below, you will find it no problem. But if you switch to 2nd gear in 3k rpm, then problem arise.
Mine still like that for more than 3 months d after i changed my gear oil to redline. I got no idea what is going on. Have you change your gear oil as well?
aycy
3,114
162
5,163
Penang / Butterworth
www.facebook.com
yaya u are right... below 3k all ok
above then got problem. is it really got problem or the gearbox itself is like this?:hmmmm::mad:
The Marketplace Top Posts
Dear ZTHians,
My proton wira with 4G15 engine has a leak. I suspect it is due to gasket problem. I have got two quotes from mechanics and one quoted me RM5xx including ordinary service + repair valve and another quoted me RM1k because he said he is unsure what other damages are there.
Well this problem has been there quite some time since my car overheated and blew its head. A new head from chop shop replaced the blown one but perhaps due to poor installation, oil leaks and I wasnt...
