street performance ideal spring rate for kelisa, kenari
upontheriversky
275
82
can anyone share their spring rate and their opinion on the stiffness and stability street performance wise?
im using hwl adjustable. im not sure whats the spring rate but i heard original hwl is 8kg/mm front,rear probly 6kg/mm. i feel that this is setup for track use since the road is smooth, but i dont do track, only fast road driving.
my problem with current setup:
-its too stiff my foot always went off the pedal after crossing bumps
- tends to skid when cornering on uneven road, too stiff it loses gripness
- tends to understeer
- even on fast straight road driving, i feel like ice skating, the tyre doesnt feel like its planted to the ground well enough
my setup:
-yokohama gp tyre
-rear arb, front upper and lower arm bar
its best if i know the stock spring rate ratio so can use high spring rate but same ratio
anyone went through trial and error with their spring rate setup? can share result and experience? i plan to swap to 4-5kg/mm front and 3 kg/mm for the rear.
i read a corolla user got best handling and comfort on 4kg/mm front and 2.88 kg/mm rear equipped with bars. corolla is heavier than kelisa which makes original hwl spring rate for kelisa/kenari is way too high for street driving
pls help anybody :D
amrancharger
779
96
wat i know is dat hwl only produce 4kg spring and above.
my viva is using 4kg front and rear.
still bumpy...
however i tink its ideal to service ur abs and request yr set up and get the advise from the rebuilder wat is the best spring rate for ur application.
i've experienced ride from a fren's myvi with 10kg spring with hwl adjustable...
and i find my bro's toyota ol skool car is more planted to the ground compare to dat myvi.
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Once ridden a kelisa equipped with titan racing custom abs + springs... its setup for 6kg up front and 3kg in the rear... although the ride is firm, it never bumps and crashes... soak off bumps rather well... just that the owner says that titan racing never did reveal to him the absorber rebound rates though...
...but i do know that kelisa goes back a couple of time until the owner are satisfied...
...currently the kelisa already sold off.....
upontheriversky
275
82
still bumpy...
hv u got any bars installed? how is ur handling experience? any understeer or oversteer? ever got feeling tyre lose contact on the road?
bumpiness i can stand, i dont want the car to fly off the ground when going thru uneven road :D
amrancharger
779
96
got the normal strut and arb from UR already on my viva...
yes...the bumpiness i meants is dat during high speed can feel the car wanna fly lol...hahaha!
maybe its due to the weight of my viva. :bawling:
however cornering improves alot even compare from GAB sport spring pair with oem abs that i used last time...
btw...im using the myvi hwl adjustable to my viva...front n rear can adjust one...
amrancharger
779
96
the myvi adj is plug n play into viva...
if need mod...i'd take the normal adjustable for viva which does not haf the hi lo function for the rear...
upontheriversky
275
82
so i suppose i can go to hwl factory and ask them to replace my kelisa rear shocks with myvi ones right?
amrancharger
779
96
The Marketplace Top Posts
my friend wanted to put on a sunroof for his wira sedan, any idea where can be done and how much? (roof-top + installation + wiring + respray)
is it advisable to do so?
