Why campro engines fail on crank!!! Campro 1.6 vs 4g92p
speed2horizon
2,798
334
1,683
ouh thnx 4 da info. dunno la my fren wanna do it.. i oso pening how come campro can be this unreliable...
I think it happens to most of the newer engine too... Sr20, myvi engine and etc
btw do u think skimming + timing belt and piston ring replacement = rm1500 is normal?
sounds ok for campro/other newer engine...
coz me do topoverhaul on my satria engine last year reaching rm1k....
and even my fren's 4g13p do top overhaul oso rm1k few days ago.. (do at diff workshop)
piston ring shud cost around rm200....so plus labour of full overhaul job i think it was quite reasonable price...
speed2horizon
2,798
334
1,683
Walaneh!!! Seems a little overpriced to me.
I had mine:-
RM128-viton valve seals
RM190-1.5mm gasket
RM180- workmanship to machine the valve seat and plonk in new valve guide
RM192-valve guide
RM160-8 intake valve
RM100 workmanship to reinstal the head.
RM35 skimming heads
Total=RM985
I had mine:-
RM190-1.5mm gasket
RM192-valve guide
RM35 skimming heads
Total=RM985
well ideally thats was the list....
but in real life is....theres some other parts need to be replaced also prior to top overhaul(mostly due to overheating)
-waterpump
-radiator hose
-waterpump pipe
-timingbelt (snapped/old)
-radiator flushing
-engine oil+oil filter
-new coolant
if u add those...then u'll understand why i quoted a bit higher price... :adore:
*blood....maybe u can ask them full quotation of replaced parts and labour
senbe84
115
Just out of curiosity,does these problem among campro still persist?Still got cases such as this nowadays?From what i heard,this is a batch faulty.Some said it's the design of target wheel dat causes this issue.So, can anyone enlight me with the info...batch problem or design problem?
i think it is more to batch/manufacturing problem....
coz if not mistaken sifu drex order new crankshaft oso one time got imperfection....so return back and newer one doesn't have problem....
i think the thread of rebuilding campro by drex was somewhere in zth....forgot where
speed2horizon
2,798
334
1,683
-waterpump
-radiator hose
-waterpump pipe
-radiator flushing
-new coolant
Sorry, I didn't know u were quoting. I though ur car were sent to workshop with that price. I did a cylinder head overhaul. Which is why it's costly. Normal top overhaul doesn't involved so many parts.
I heard of the target wheel too. Somehow only cylinder 1-4 matches the tdc, but the 2-3 cylinder didn't when the target wheel is turned 180 degree. That's what I heard. Just sharing, no offense.
jswong
209
9
3,018
Putting the target wheel on the *inside* of the crankcase with the crank angle sensor located so close to it seems to be cause of the problem, because it seems like in all the cases, the destruction of the target wheel leads to the fracturing of the flywheel-side of the crankshaft, the same area the target wheel is mounted.
Could it be that power shifting or clutch-dumping at high-revs result in momentary shocks that are not properly absorbed/dissipated by the crankshaft end/thrust bearings, thus causing the target wheel to be deflected towards the crank angle sensor?
Apparently the 4G18 crankshaft has similar dimensions to the S4PH's crankshaft, except that the balancers are a bit larger and thus the crankshaft housing needs to be skimmed a little for more clearance. I wonder if anyone has modded the 4G18 crank into the S4PH block, and used a crank pulley similar to the 4G15 SVDO's, with the target wheel located externally, and use it together with the 4G15 SVDO's external hall-effect crank angle sensor.
senbe84
115
Only campro carries a design which have target wheel inside the crankcase?does other engine design do the same way?If only campro does dat, meaning maybe the campro design have weak spot but if other engine maker does carry the same design,maybe its a material failure...Just wondering...
speed2horizon
2,798
334
1,683
different stroke...
The Marketplace Top Posts
Im using wira...anyone had done this....the cover in the middle console n near the meter.....can anyone show me the step....n good quality paint to use....
