4G91 Gang..
MiTec-i
852
16
3,018
Kay L
www.teamfuze.rules.it
i used to had 1-3 gear using proton's 1.3 gb 4th&5th from a GTi....final drive and differential using mivec....was great...but didnt last long...6 months...mayb due to poor workmanship or my recipe not working....u can try if u want...just wanna say it's possible
aLoM
28
1,503
having some issues here. 92 non mivec with 93 head. currently having ecu issues(capasitor leak). lets say i cant fix the current ecu(ecu code : MD178330-couldnt find it on the net),if i change the ecu with another unit but different code. do i have to change the air flow sensor as well?cant remember the air flow sensor code. if im not mistaken its 449.
thor03
Dec 5, 2010
49
508
Mitec-i, ooooo really where u do it...... how it feel......... what do umean workmen shop not goog? by the way what the different final drive and differential using mivec compare gti, I thought gear only 5, ang 5th gear is final drive....... can xplain.
MiTec-i
852
16
3,018
Kay L
haha...i didnt knw where he send it...machine shop i guess to pump out the gears and put it in...plus tat workshop close shop already...lol...i can try ask around if u really wanna play ratio...some of my frens doin it...so if u wan....i let the pros explain to u...
thor03
Dec 5, 2010
49
508
sure.... sure..... because i'm thinking to put gearbx 1.3 for 1 n 2 at my gti.......
joe_mirage
1,030
44
1,648
rotationperminute.blogspot.com
hi guys! its been ages since my last post :P .. btw i just wanna share with you one of the craziest 4g91 setup. picture below
the exhaust setup.. phewwwwwwwwwwwwww :burnout:
joe_mirage
1,030
44
1,648
yeah. for drag use only. btw that isnt my engine :)
btw the coil that u see in the picture above is msd
thor03
Dec 5, 2010
49
508
joe miragei already read your blog a long time ago...... last time used 4g93 then change to head mivec rite..........
could u tell me about this coil MSD, is it plug n play..... n benefit we used it, if the ignition to big also not good rite...... what the spec of car when we need to used this MSD or it's got other advantage.......
hope u don't mine..... thanks
joe_mirage
1,030
44
1,648
mitec:
got one workshop can do it. in gombak i'm not mistaken. A.H.S workshop. try search in mudah.my.
thor:
if i'm not mistaken, if u wanna use msd you gotta have management system. so, it is not plug and play :)
btw, i'm not really familiar with msd so i cant tell u much about it. sorry bro. hope anyone here can help to add more info about it?
ACQ2305
984
184
HeadHunters
thats a wicked looking engine Joe,..what's the power output???
Aug 11, 2009
Shah Alam
all otai
recently i just bought satria 4g91 injection manual.after a month i had changed aerospeed triplecore spark cable (coz existing already missfire)+denso iradium spark plug+k&n open pod.now my car seems loss power i.e. no top speed n fuel consumption also bad (rm20 from shah alam to klang bukit raja for 2 days and drive in relax mood).there is always jerk in 3rd gear and sometime in 4th gear.sometime when i turn on aircond,the car semput2,and afetr turn off,back to normal.my fren told me may be due to throttle body but my rpm is ok (less than 1, and above 1 if aircond is on=normal rite...).fyi, my piping is a standard 1.3.wanna change to 1.8 inch but want to resolve that problem 1st.i had changed also fuel filter,airflow sensor b4 coz a pomen advised that.i bought this car for everyday working use n now this problem really made me not cool...plz advise all otai out there tq
joe_mirage
1,030
44
1,648
if i'm not mistaken almost hit 15+whp on dyno dynamics... on dynojet might be higher :)
alvin24
3,109
27
5,148
Jeo's car damn nice... now got power heart to go with the killer looks ! =) awesome stuff!
aee1717,
Double check everything related to ignition and fueling.
i wanna ask about 4g93 sohc carburetor whether can pnp 4g92p intake and cam? any sifuss can help me??
