Widest tyre to fit a rim size
gIGoN
327
Hi guys,
Please advise me what is the widest tyre which could fit the following rim size:
1. 6.5jj
2. 7jj
3. 7.5jj
maxximuz
26
2
1,503
1. 6.5jj = Min 185 ; Ideal 195 or 205 ; Max 215
2. 7jj = Min 195 ; Ideal 205 or 215 ; Max 225
3. 7.5jj = Min 205 ; Ideal 215 or 225 ; Max 235
maxximuz
26
2
1,503
1. 8jj = Min 215 ; Ideal 225 or 235 ; Max 245
2. 8.5jj = Min 225 ; Ideal 235 or 245 ; Max 255
3. 9jj = Min 235 ; Ideal 245 or 255 ; Max 265
gIGoN
327
guys, i bought this second hand rim which has 7.5jj and the tyres fitted wuz 245/45/18. Is it ok if i replace with the same spec? The tyre seems to be holding on fine.
viper5965
363
20
it only effect your poket......tyre price and fuel consumtion bcoz widest tyre friction..:idea:
it yr choice,if ur capable u can replace with same spec..:listen::biggrin:
gIGoN
327
just tried fitting it into the car and guess wat it wont fit with 245/45/18.
would 245/40/18 be safe on 7.5jj since currently it's using 245/45/18
r3dster
633
27
5,028
shoud've been more specific.different car, different fitment. aspect ratio for an evo and r32 is different.245 on a 7.5jj is considered too wide.225/40 should fit nicely
hoho...
when wanna go tt?
pangyau
1,153
302
1,683
Malaysia
Asking an advice,
I have a 17 X 8.5jj offset +30 for the rim.
Which the best fit tyre for it?
1. 235/45/17 or
2. 245/45/17
My intention is to protect the rim also.
Seem the 245/45/17 kinda hard to find in my place.
Thanks in advance
Fitting what width tyres to a rim, depends on their aspect ratio also.
Does not mean 225 will fit 8JJ better or 7JJ better.
For example 235/45/R17 will fit 8JJ, but 235/55/R17 will fit 7.5JJ better
r3dster
633
27
5,028
also dont forget it also depends on what car as well.different car have different wheel arch size as well maximum width where by ideally a certain size is good for a particular rim but it wont fit the car due to width issues...
just my mili cents....
Topic is on what size tyres fits what rim size.
For fitment to cars, always work from original tyre size, then whether plus 1 or plus 2 factor, then work out tyre wide and tyre aspect ratio, not to be more than 3% over the original diameter
nikolaiski
88
36
Hey guys..
I'm currently running 215/45 17" on a 7.5JJ offset +35 rim (Evo brembo on a Lancer CS5 4G93T)
I want to change to 8jj rims where there are alot of +35 offset sizes, BUT don't want to put 225/45 tyres on them because sure to rub my fenders (roll already!) when I go track (must set coils to a lower setting to be ideal)
Is it possible to run 215/45 17" on an 8jj and safely go to TRACK and up and down NSHW from JB-Penang once in a while, ie. drive like gila? lol
Recently bought a Pro******* Brands Rain Stain Removal, it really removed the rain stain. I applied it to all my car's glass mirror including both side mirror as well. It gave me a good result. However, when come to the front mirror, oh .. god..! I realized that the rain stain has gone, but it gave me a big trouble. The front mirror become matte surface, blur on the surface. It cannot be removed even I applied the rain stain remover for few times. I dunno what happen. Do anybody know how to...
