check whether ur oil level is reducing
if yes turbo seals n need service
open ur air filter pipe/hose
check if ur fin got free play front and back or sideways
if front n back then the fin will touch the compressor housing and make whistling noise also
aiyoh...now i change to SQV..same problem occurred...no sound from SQV...and i addd an extra injector, i i saw the connector of the intercooler is quite oily..do you think that the connector need to be change? do you think that the connector loose when the oil soak in it?? help help!
I need help with my FD. Got this wierd problem. On cruising and occasional flooring the car is fine. But when i go drag racing, the 1st 4 gears are fine, but when i upshift to 5th the rpm can't climb. It...
