VW Beetle Custom & Performance
sigh...still no sign of any of these engines.... btw..the other night i saw one herbie lookalike beetle in pandan indah cheras... complete with the stickers and everything... just the exterior la.. but dun think got canvas roof though...
mathen said:
call me at 016-6766075 for spare parts enquiry... still can get most of it.. don't give up yet.. new german or brazil parts..
nice bro...im looking for front disc brake...full set..n lowered spindles 2 1/2 inch dropped
thanks aircooled for sharing ur good info... so wut stuff that u have to sale...heard u have lot of performance part
1. i used to have a lot of things for sale, almost all sold off, now only left a 84mm CB Performance forged counterweighted crankshaft for sale. got some bits and pieces, but i lazy to dig up.
2. Firna racing pulley? i dunno what is that and i dunno how it looks like, but with your 1600cc engine, i dont think you will need any racing pulley. Stock pulley is more than good enough.
i try it...its good...ringan...84mm counterweight...scared to play lar bro...
if got project can lor....bring it to sepang ..hehe
angkat kepala...hehe..
dont lazy lar bro...try find it...hehe..if uve got very good parts...
ok, yeado help to spread the words around....wana push the crank away, still new in CB packaging, i paid USD299.90 for it excluding freight UPS and tax. willing to let go at a reasonble price to the person who neeeds it.
yea, will see what bits i have left.
wow...that is very good interest.....u dare to take out ur money in the pocket...cayalah bro...
so i wish u will share ur info in here...coz im not too otai lar...just played with this weird thing since 96 after spm....
many type of people that ive seen..hehe
ok then aircooled...hehe
ops...cari u punya part apalagi yg tinggal n tell me...hehe
some infos...
Choosing the Right Distributor
Aircooled VW owners have an assortment of options when choosing a distributor for their engine. If you only look on the surface it seems simple: The "obvious" choice is the Bosch 009, right? Not necessarily. Once you do a little research, you'll find a variety of stock units (including the SVDA unit), as well as the Bosch 009, 010, and 050 series, and finally the Mallory, MSD, and the age old Magneto. So which one is "best"?
Each of these units is excellent - for the right application. In this article, I will clarify the right time and application for each option available. You can read the entire straight through, or skip directly to your area of interest using the quick links below:
o
o
o
o
Stock Engines
"Old Faithful", the VW Stock Distributor (Vacuum Advance)
We will start at the obvious place, which is the beginning. Up through the late 60s, VW supplied their engines with the stock distributor, which was a non-smog distributor (emissions were not an issue). These vacuum advance distributors do their job well, and all are dependent on a vacuum signal from the carburetor, (with the exception of some early type 2s, which were chronically under-powered and used a centrifugal only distributor). Stock units work VERY well when installed in stock or near-stock engines with 28 or 30 series carburetors. Most complaints are related to a defect of some sort (bad points, condenser, worn out distributor), or a problem that is giving symptoms of a bad distributor, but is actually fuel system related.
One of these two modifications are the most common:
1. The carburetor is changed to something other than stock, and it is almost always missing a vacuum port for the vacuum advance distributor to operate properly.
2. The high performance engine does NOT have a proper vacuum signal due to a long duration camshaft.
Cam overlap can cause a drop in vacuum, and obviously, the vacuum advance on a stock carb and distributor won't work together properly. We have introduced the most advanced distributor the VW market has ever seen to solve this problem.
The 010 Distributor
Bosch came to the rescue with the 010 Distributor for early hot-rodders. This distributor eliminated the vacuum advance system, and used ONLY engine rpms to dictate the ignition timing. For high performance engines of the time, this was the perfect solution, since these engines were usually run at idle or full throttle! :-)
The 009 Distributor
In 1971 (in the USA) the VW engines were shipped with a "smog" distributor, which had a vacuum retard in addition to the vacuum advance. The engines were also changed to the dual port configuration, along with a change in carburetors from the 30 PICT series to the 34 PICT series, which had the additional port for the vacuum retard. These new carbs were also LEAN in their operation, since they had to conform to the new tailpipe standards.
The 009 distributor was introduced, and was a very inexpensive "replacement" unit for VW engines, and it was almost a duplicate of the earlier 010 distributor.
These 009 distributors were (and still are) sold by the ton. Early VW engines (pre-71') had no problem, but the smog engines when equipped with the 009/010 distributors had a pronounced and annoying "flat spot". A "flat spot" is a hesitation just off idle, and can range from being almost unnoticeable to getting broad-sided or rear-ended by approaching cars! (Many 009/34 equipped owners mistake this hesitation for POWER. They don't notice the hesitation, but they DO notice the kick in the back of the seat once the engine catches and it starts accelerating! They mistake this for "more power" since there is such a difference between the stumble and actually operating properly.)
The vacuum advance distributors do not have this hesitation since they advance the timing when the throttle is opened as part of their operation. Obviously, the 009/010 is only rpm based, and this vacuum advance doesn't happen. When a 009/010 is combined with the lean SMOG operation of the 34 series carb, the flat spot is the result. Current "solutions" are all modifications to the carburetor, which richen up the fuel delivery in various forms, whether it's the idle circuit, the main jet, and/or the accelerator pump circuit.
The error with these "fixes" is that they are curing a symptom, not THE PROBLEM. The problem is the lack of additional advance just off idle, not lean operation. The stock distributor/34 carbs didn't have a hesitation!
The SVDA Distributor
Enter the SVDA distributor. A production VW distributor with the 009 advance curve (close enough), and a vacuum advance unit! Believe it or not, there is an additional advantage to the vacuum advance (on engines that have the proper vacuum port; 34 PICT series carbs), and that is the gain of 4 mpg improvement over the 009/010 distributor! Same performance, plus 4 mpg improved mileage, and NO FLAT SPOT.
The drive-ability of the SVDA/34 carb has to be experienced!
30 Series carbs can NOT use the SVDA distributor since the vacuum signal is not correct and won't pull the advance in on the small canned SVDA (you notice the early distributors use larger vacuum cans than later distributors because the vacuum signal is different).
Modified Engines
When the carburetor is changed to something larger than stock, the vacuum signal is lost, so the centrifugal advance units ARE the proper distributor for this application. Now you are lost in a multitude of choices: 009, 010, 050, Mallory, MSD, and Magneto. Which one to use?
What you want is to set your ignition timing about 4 degrees retarded from the point where detonation begins. This setting means the flame front will meet the piston at the top, maximizing cylinder pressure and the time (crank degrees) to push the piston down, making the most power. If you ignite the charge too late, the pressure doesn't build until the crank has rotated some, and you lose precious crank degrees (HORSEPOWER) of work. If the charge is ignited too early, the flame front will hit the piston ON THE WAY UP, and this is a sure-fire way to destroy your engine very quickly.
What is needed is to find the timing point at EVERY RPM point where you are around 4 degrees retarded from detonation under full throttle, since this is the "ideal" time for our spark to occur. Obviously, you would leave yourself a safety zone of 3-4 degrees of timing at all points to CYA in case of bad gas, clogged main jet, vacuum leak, abnormally hot engine, etc. The power difference between detonation and 3-4 degrees of retarded timing from this point is negligible, so riding the ragged edge of timing is not worth the risk, IMO. Detonation does NOT have to be audible for it to turn your expensive mechanical marvel into junk in short order.
Finding the Advance Curve
Ideally, you would remove all advance from the distributor, and run a locked timing. You then put the engine on a dyno, and play with timing across the RPM band from idle to redline at full throttle (finding the timing where you are 4 degrees from detonation) and then chart it. Then, you remove the locked timing from the distributor, set your initial timing to match what you found was best at idle. Next, match the distributor's curve to match what you found to be best on the dyno by changing weights and springs in the distributor.
If you have the patience and time to set up this custom curve, and have a heavily modified engine, your patience will be rewarded! Get yourself a Mallory/MSD distributor. You will find they are VERY adjustable. The easiest method to follow is very straightforward. Find the MAX advance point your engine tolerates (between 30-40 degrees BTDC) above 3000 RPM. Now find the place where it responds best at idle. It may be 15-24 degrees BTDC. You may find that this much advance causes starting difficulties when the engine is hot, so be sure to check this out! Ignition before top dead center causes "negative torque" and that's what suddenly STOPS your engine from cranking. Avoid this, or use a retard that is activated during cranking.
Now, you know the two critical points in your advance curve. You only need to figure out how FAST you want the advance to come in. I recommend being conservative, and kick the advance in SLOWLY and see how the engine responds. Keep adjusting it (it requires distributor disassembly) so it comes in quicker and quicker, until you detect detonation (problem). Back it to the previous setting, and you are DONE with the centrifugal advance. Now, dial in 10 degrees of vacuum advance, and adjust the advance so the carb(s) will actually activate it and you are done! PHEW!
Frankly, though, finding the advance curve using this method isn't practical for most of us.
The 009/010 is best used for stock rod ratio engines, where you do not want to do all this customer ignition curve work. Let me first say that I'm not a fan of the 050. The 050 has a different advance curve, and it's more suited for short rod engines (like the type 4), or engines with a bigger crank and shorter rod (78 stroke with Porsche length rods, etc).
If you are using an out of the box distributor (009/010/050), you have to set the timing as advanced as you can so it doesn't detonate at full throttle (where you would have a problem with a centrifugal only distributor). Problem with this is, you are setting the WHOLE CURVE BASED ON THE MAX TIMING AT ONE PLACE. This in itself is significant. You are finding the point in the rpm range where you can't advance any more, even though at many (all) other rpm points you are too retarded! THIS is exactly why setting up a custom distributor advance curve is the ideal solution, but not everyone has the time/patience to set it up. Obviously a fully adjustable setup like a programmable Haltech makes this very easy on a dyno since you just tap a few keys and you are on your way, not like changing springs and weights in the distributor every time you have to make a change. However, we have a new distributor that makes this task EASY; inquire for details.
Ignition Basics
Now I want to cover one MORE ignition topic that is important to consider. The ignition is separated by PRIMARY and SECONDARY parts. The primary ignition is the low voltage side; points, condenser, etc. The secondary ignition is the high voltage side; coil, cap, rotor, wires, and plugs. The primary side of the ignition is responsible for the triggering of the spark, and the secondary side is responsible FOR the spark.
Primary Ignition
In my opinion, points are obsolete (sorry to be blunt). Unless you like messing around with them, replace them with some sort of magnetic triggering device (Compufire, Pertronix, etc; Aircooled.Net carries the Compufire). These do not increase your spark quality (like some claim) compared to a properly operating points triggered ignition. However, they do not deteriorate like conventional points/condenser ignitions. They are exceptionally reliable, and they will be rock steady at all RPMs, which can not be said for points. Basically, the magnetic pickup assures optimum triggering all the time. Simply buy the magnetic pickup points replacement unit and throw the points in the glove box in case you have a problem with the magnetic unit. The MSD distributor comes with the magnetic pickup as part of the distributor, so you don't have to worry about it on that model.
Secondary Ignition
This is another place where large improvements in engine operation can be gained. Frankly, the stock Bosch coil is only adequate to about 2500 RPMs, and the spark quality deteriorates from this point and up. The problem is with the coil's primary voltage (12-14V). As engine RPMs increase, there is less time for the primary voltage at the coil to create the required magnetic field that generates the high voltage spark we need at the plugs. There are two solutions: 1) increase coil current. The problem with this is that you will burn out points (if equipped) much faster, since the coil's current is passing through the points. 2) increase the coil's primary voltage. This is the solution that Jacob's, Universal, MSD, and other companies have decided to use. There is no drawback to this solution other than cost. We carry the Universal and Jacob's systems at Aircooled.Net.
Once the secondary ignition is improved with a CDI or Jacobs, the spark plug gap can be increased to 0.040-0.045". Be aware that you may have to re-set your timing, since the larger plug gap and better spark can speed up the time the flame front reaches the piston (detonation). You will find smooth running at all temperatures and INSTANT starting (not like before), with a 10-15% increase in mileage. This savings in fuel will pay for the CDI quickly!
High Output Engines
Another issue that you must be aware of is that high output ignitions MAY have a problem with the small diameter distributor caps on the Bosch units. There is a reason the MSD and Mallory distributors have a large cap, and that is to minimize the possibility of the spark jumping to a contact that it is not intended for! Another problem is that the Bosch rotor has a resistor in it, which WILL burn out in a short period of time if used with a high output ignition. You can dig it out, and solder a solid piece of brass in its place (it's between the tip and the cap contact area). Our new distributor has a large cap and bulletproofrotor, so that's easy!
The Magneto
A last option for ignition system is the Magneto. A Magneto is basically a generator, coil, and distributor in one unit. Watch out, they're heavy! These are wonderful products, but they have a VERY limited application. In my opinion, a Magneto should ONLY be used in applications that DO NOT HAVE A BATTERY, or that are REQUIRED to have self supporting ignition systems (aviation?). Computer ignition systems have better sparks than Magneto's, and Magnetos are very heavy and they draw power off the engine to generate their spark. If you have a battery and a computer ignition, the computer automatically steps up the battery voltage to whatever the engine needs even if battery voltage drops to a low level. Having a Magneto AND a battery/generator/alternator is redundant, in my opinion. If the vehicle has no battery, and is externally started, the Magneto is the obvious choice.
Distributor Application Summary (the article in a nutshell, without all the details).
Stock Distributor - For stock engines.
SVDA Distributor - For 34 PICT equipped engines.
009/010 - For modified engines, where no ignition fine tuning is desired.
050 - For engines with a relatively short connecting rod. (I personally don't like these distributors).
Our New Unit- For modified engines where the owner/builder wants to customize the ignition curve The fully adjustable vacuum advance increases your gas mileage by 4-5 mpg on the highway, and increases part throttle power. The fact that it works withthestock coil OR any aftermarket CDI (Jacob's, MSD, ours, etc.) is icing on the cake. These features make this unit the premier distributor in the VW Industry!
MSD - For modified engines with a custom ignition curve, magnetic pickup, and that can be easily connected to a MSD ignition unit (5, 6AL, 7AL2/3, etc).
Haltech/Electromotive - For the high tech junkie that wants infinite adjustability in their ignition timing.
Magneto - For engines with no battery or source of electricity (generator/alternator).
Ignition Wires
From someone on the RAMVA Newsgroup wrote - I would stick with the stock type ignition wires as they often have a lower resistance than silicone wires with graphite leads.
Rob reported that his original set of spark plug wires stayed in the car 18 years till they became hardened and brittle. Dave, being obsessive and ultra-conservative, replaced his after only two years.
Dave wrote to John Connolly (Aircooled.Net) - I'm not clear about the plug wires for use with the CDI system. Some say the sturdier wires (i.e., Jacob's or Megavolt) are necessary; others say the stock wires are just fine (mine are almost new -- I'm loath to replace them already).
John responded - If they are almost new, don't change them. However, give them a check once in a while, because the additional spark energy can break them down quicker than with the weaker stock ignition.
Rob wrote - There is a possibility that the STANDARD plug leads will occasionally arc.
Spark Plugs
See our article on Reading Spark Plugs.
Someone on the RAMVA Newsgroup reported good success with NGK spark plugs.
Dave wrote to Rob - My Bug is starting to run rough. I think its those cheap Champion plugs I put in a few months ago, just because they were hanging around my work bench. I'm going to try to find a set of the NGK plugs -- B5HS for the 12mm ones, if memory serves. Rob responded - B5HS is the standard electrode plug. These are the ones I'm using, and they are working.
Rob responded - I have the NGK Spark Plug Guide in front of me...
The NGK letters and numbers mean -
B - The thread size -- 14mm plug (A-18mm, C-10mm etc.).
5 - heat range - 2 is very hot, 13 is very cold.
H - thread length 12.7mm (E for 19mm).
S - "standard" electrode type (Y for grooved, P for platinum, V for precious metals, etc.
You might come across an additional letter for the plug gap -- 9 for .9mm, 10 for 1mm, 11 for 1.1mm, and 13 for 1.3mm (but not on the plugs suitable for VW).
The 6 heat rating should be OK - it's just a fraction "colder" than the 5, and should be OK in your hotter climate. "Colder" for a spark plug means that it gets rid of heat faster than a "hot" plug.
But you said B6SS - the character after the number should only be an H or E indicating the length of the threads. There is no S length - only H and E. If you really meant B6HS, then yes - that should be fine.
Black and oily usually means that the engine is starting to burn a little oil (starting to get worn). If you use a colder plug (the B6HS) there is a possibility that they will oil up more, but there's no way of telling untill you try them and see if they oil up too fast and stop working.
Rob responded to another query - Just to check, are your old plugs the 1/2 thread, or the longer 3/4 inch thread? If your car has the newer style replacement heads (they are interchangeable), they will need the 3/4" plugs -- B5ES ("E" for "extended" thread).
With the engine out, it might be possible to shine a torch down a plug hole and check. If the heads are the newer 3/4 inch type, and you have 1/2 inch plugs in them, you'd see a blackened section of unused thread at the bottom of the hole. The short plugs will fire in the newer heads, but less efficiently, as they will be "buried" inside the heads.
Regarding grooved electrodes, Rob wrote - B5HY is the equivalent grooved electrode version. The multiple electrodes tend to shield the spark from the mixture a little, which is okay in a slow revving aircraft engine, but not so good in a higher revving auto engine. Then they developed a "surface electrode" type, which had the cavity filled with bakelite or similar, and the spark jumped from inward facing 'bumps' on the rim to the inner electrode, all of which were flush with the bakelite filling the cavity. Supposed to be harder to clog, because there was no cavity to hold the gunk. Not even used in cars to my knowledge. NGK do make a grooved electrode plug though, and this is supposed to make the spark on the outer edge of the side electrode, instead of jumping to the center electrode right in the middle. Supposed to eliminate any possible shielding of the spark -- more exposure to the fuel/air mix.
In response to a query, Rob wrote - The VW engine works best with Bosch WA8C or NGK B5HS plugs. (Champion L87Ys are the right heat range too, but they have cut threads -- not rolled -- and tend to strip out the aluminium heads.) You can do a plug test by running down the road at a good speed (with the engine properly warmed up), and shutting off/declutching/turn engine off in the middle of the run, and coasting to a stop. This is necessary so the reading is not contaminated by any idling.
The plugs should have a grey/black thin coating on the rim of the threaded section. The center porcelain insulator should be off white, turning darker deeper into the plug (about 1/2 way down the insulator) and the tips of the outer electrodes should be grey/white, turning darker on the bend, to blend into the dark grey of the rim of the plug. Black/oily is a good indicator of a worn engine. Black/sooty means it's running too rich. Brown /whitish insulator and a 'white all over' outer electrode usually indicates lean running, often accompanied by a light coloured rim on the plug. If the rim has a speckled "pizza" appearance, the engine is detonating (even if you can't hear it), and you try a different brand of fuel of go to the next higher octane fuel. And of course if the centre electrode has rounded edges instead of a 'squared off' end, and the outer electrodes are looking thin and burned, the plugs are past their best and should be replaced.
If you can avoid using oxygenated (MTBE) fuels, do so -- your engine will run smoother. Oxygenates result in less "fuel" in the fuel, and make old carburetted cars like the beetle run lean, which means running hotter, and they don't like running hotter since they are a hot running engine anyway. If you don't have a choice, try switching brands, and DO use a "pump octane" of at least 87 -- maybe higher if it needs it to avoid detonation.
If you want to make it last forever, or at least longer than the 70,000 or so it normally lasts, get rid of the points. Opening the points represents as asymmetric load on the distributor. Opening the points is the major cause for wear on the shaft and bushings. So get rid of them. Use a Pertronix unit. No load on the distributor shaft. Runs concentrically. Vastly reduces the wear-rate which is already pretty low because the distributor only turns at one-half engine speed. (Don't use an optically triggered unit. The Pertronix is magnetic.)
Buy a Pertronix 'Ignitor' that fits your distributor. Pull the distributor and install the 'Ignitor'. Be careful of the wiring. One lead is +12v, the other is the signal lead... it goes to the coil's negative terminal. The ground is internal through the body of the distributor.
Be sure to set the proper air gap and make sure the Hall effect sensor (the black epoxy cube on the aluminum plate) is standing square to the plate. I've installed several of these and most were bent right out of the box due to improper riveting. Easy enough to straighten but if you don't notice it the thing can actually rub against the magnet ring... not a good idea. (And yes, it's 'magnet' not 'magnetic'. There are four high-strength magnets cast into the nylon (?) ring that fits down over the cam lobes of the distributor shaft.)
Make sure the magnet ring is pressed FULLY down onto the cam lobes. There are instructions with the Ignitor but the illustrations don't look much like the real thing.
Put the rotor back on. (You can expect to wear out a rotor about every two years due to the higher spark voltage. Just carry a spare so it won't leave you stranded. Ditto for the cap.) Make sure the ROTOR seats fully. On some distributors, you can't use the 'Ignitor' because the magnet ring prevents the rotor from seating full depth. (But you can machine a bit off the lower edge of the rotor, if you're careful doing it.)
Fire it up. Hey! Now THAT's a difference. Reason is,you've just eliminated a lot of mechanical jitter that is present in most old distributors. The jitter is still there but the triggering method used by the 'Ignitor' masks it. No more points bounce. In fact, no more points, period. Your plugs are now being fired in response to an electronic signal that is far, far more precise than any mechanical switching arrangement.
Slap a strobe on that puppy. And plug a sniffer up the tail pipe -- you can lean that thing down by quite a bit, now that you've got a higher spark voltage. Static timing okay? Then go ahead and kick it up to where the advance is all in and check the max. Dial it back down to thirty degrees or less. (I run 28. Yeah, I know. But I'm more concerned with getting there than how fast I can get there.) Hot weather, bad gas, heavy load, crank it back a bit more. And tweak your idle down better ignition has caused your idle rpm to increase. Keep them between 800 and 900 rpm. Any slower and the engine won't cool properly when you come off the freeway, etc.
Now here's what's gonna happen. Your mileage is going to take a nice jump. Most folks report an improvement of 8 to 15 percent. Depending on how much you drive, that alone will pay for the mods in about two years. But the driving! Damn! The thing really DOES run better! That's because you've gotten rid of points-bounce and shaft-jitter and incomplete combustion at higher rpms. And that means your engine will last a little longer because your oil is going to stay a little cleaner because there won't be so many unburned hydrocarbons in the blow-by that gets into the crankcase.
Plus it's going to start better. A LOT better. And no more cross firing during damp weather. And your engine is running cooler, too! Those Corvair-type air seals really make a difference.
I've been using such an ignition system for nearly thirty years -- it's been available that long. I first wrote about it on the internet more than five years ago... and immediately got a blizzard of flamers and hate mail -- lots of kiddies shouting 'If it's really that good and really that easy, then why haven't we seen anything about it in the magazines?'
There Are Four Different Ignition Systems
You Can Use On a VW
1. The Stock Points/Condensor System. Works okay, but the voltage at the plugs gradually drops as the rpm increases (this happens with all points/condensor systems) and the points will also start to "float" at very high rpm. The plugs get about 18,000 volts. The points wear fast because they have to switch about 5 amps, and so they spark. The condensor reduces the sparking but it still happens so the points wear out (burn). The spark also slows down the switching process, so the coil gets a "soft" switch and the resulting plug voltage is a little less than it could be. (The coil produces the high voltage to the plugs when the points open and the magnetic field inside the coil collapses. The faster you can cut the power to the coil the faster that field collapses so the better the plug voltage).
2. The Pertronix/Compufire Points Replacement Modules. These replace the points with a hall-effect sensor or (in some earlier models) an optical sensor. They electronically switch the power to the normal coil, so the coil is still working at 12 volts (but the elecronic switching is faster than the sparking points so coil performance is a little better). The plugs get about the same 18-20,000 volts. These points replacement units don't wear so your timing stays very steady and doesn't need adjusting much.
3. Transistor-Assisted Ignition. These use a very small current through the points to switch a power transistor on and off (imagine the power transistor as an electronic relay - using a small current to switch a bigger current) and the power transistor supplies a normal 12 volts to the coil. But like the Pertronix it provides faster switching than sparking points can, so coil performance is a little better than stock - still in the 18-20,000 volts range to the plugs though. The points last a long time as they don't spark any more - only a tiny trigger current flows through them. These systems are not very common these days, but will work well, and are easy to build. You could consider these sytems as a cheap alternative (but roughly equivalent) to the Pertronix/Compufire.
4. Capacitance Discharge Ignition (CDI). This can be triggered by systems #1 or #2 above, but is not used in conjunction with system #3 at all. (Consider it as a BOOSTED #3). The CDI system has a couple of very large capacitors continously charging from a high frequency circuit using a "toroid" (donut shaped) transformer inside the unit (the high frequency produces the characteristic whine like a camera flash charging up) and when the points or the Pertronix triggers it, the capacitors dump about 400 volts through the coil, so you get about 40,000 volts out of it for the plugs, rather than the normal 18-20,000v. This provides a thinner but much hotter spark which will light a weak or rich mixture, so you get easier starting, and you also get slightly better economy, and your plugs last longer. And of course - if you use it with the normal points, the points will last a long time because they are only providing a small trigger current - the capacitors are providing the main pulse to the coil. You can open the plug gap a little with a CDI - for a longer spark. Up to about 0.045", but if you set it at 0.035" you can forget the plugs for many thousands of miles - the electrodes with still burn away slowly, but won't go "over gapped" because you started with a modest increase. One useful feature of POINTs fired CDIs is that they can be used to upgrade the ignition on early VW engines and still retain the retarded #3 ignition which is needed for the non-doghouse engines.
MSD is usually a variation of the CDI - providing a multi-spark rather than a single spark.
There are also magnetos which will fit the VW engine - these are self contained ignition systems - no battery is needed, and are sometimes used in VW aircraft engines.
As we all know, the babies we all love so much are cooled by air. Adequate cooling of the VW engine, and the flip-side, overheating, are concerns.
In any system in which work is being done, the Second Law of Thermodynamics dictates that some of the energy produced is wasted in the sense that it cannot be utilized for work. This waste energy, in the form of heat, must be transferred to a “heat sink.” In a water-cooled car, the water circulating through the engine block and heads carries the waste heat to a radiator, where the waste heat is dumped to the atmosphere. The atmosphere is also the “heat sink” in the aircooled VW engine, but in Volkswagens the waste heat is removed from the engine by flowing air rather than water. Finning on the heads and cylinders facilitates the heat removal, and a cooler is provided in the system to remove heat from the engine oil; heat is also carried from the oil cooler by flowing air.
We are often asked, “What is the best way to keep my Bug cool?” And being the stock enthusiasts that we are, we respond, “You already have (or perhaps, had) everything you need.” Volkswagen engineers recognized from the outset the importance of keeping the engine cool, and they came up with a very efficient design, consisting of a blower (fan), a set of air vanes, thermostatically controlled flaps, air dams and deflector plates. This system is designed to efficiently direct the flow of cooling air toward the cylinders and heads, paying particular attention to the exhaust valve areas of the heads.
The smart VW owner will watch carefully for the tell-tale signs of overheating. In his technical manual(1), Gene Berg states that the safe upper oil temperature is on the order of 235F (113C) so. If the temperature is higher than 235F, the heat can cause case studs to pull out, head and case sealing surfaces to warp, cases to be internally distorted, permanent case metal fatigue and engine bearings to wear prematurely. Sounds like a horror story, but it is easily prevented if a few precautions are taken and followed religiously.
How Do You Know If Your Engine Is Running Too Hot?
There are several of ways -
* The “Poor Man’s” Dipstick Test -
With the engine completely warmed up, grab the dip stick and pull it out. If you can JUST hold it without it burning your fingers, the engine temperature is OK. If it burns your fingers (and the engine will usually smell hot too), then the temperature is too high -- possibly as high as 285F (140C) -- VERY hot!
* Install an Oil Temperature Gauge -
An oil temperature gauge requires an oil temperature sensor/ sender. There are two types of oil temperature sensors -
o Oil Sump Plate Sensor. This sensor will screw into the oil drain plug hole, but the sensor extends upward enough that it impinges on the oil screen assembly. The instructions that come with this sensor say to drill another hole in the plate, to one side of the plug, thread it, and install the sensor there. Some oil sump plates have no drain hole. If yours is one of these, drill and thread a hole to the side of center for the sump plate sender.
o Oil Pressure Relief Plug Sensor. If your engine is equipped with a dual oil pressure relief system, you can replace one of the plugs (i.e., the front one -- at the flywheel end of the engine) with an oil relief plug sensor and save yourself the hassle of drilling a hole in the oil sump cover plate.
Oil Relief Temperature Sensor(2)
This sensor screws into the forward oil pressure relief
port --assuming your vehicle has two ports. If not,
you will have to install the oil temperature sensor in
a hole you drill in the oil sump plate.
Oil Relief Temperature Sensor Installed.
Note: Our oil temperature sensor installed in the forward oil pressure relief port. Note the wire running forward -- be sure to attach it securely with clips or cable ties so that it doesn’t interfere with the workings of the heater boxes, etc.
Wiring instructions come with the gauge (e.g., VDO). Generally speaking, you run a wire from the sensor up to where you install the gauge in the cabin. You will need to drill a small hole in the floor pan behind the rear seat so you can route the wire into the area under the rear seat, then forward from there). To wire the gauge you simply connect the gauge to power (we used the #11 fuse) and to ground, and you’re all set. In our Superbug we found a nice place in the dash to install the gauge, just to the left of the steering column.
Oil Temperature Gauge.
We found the perfect location for our gauge in the dash panel of our Super, immediately to the left of the steering column. Access is a bit difficult unless you remove the steering wheel. Using a right-angle attachment on the drill, we drilled a series of holes around the circumference of the larger hole for the gauge, then connected them with a coping saw blade. A bit tough on the fingers!
A word of caution from Gene Berg: “Practically all (temperature gauges) read low in the 212 to 260 degree range by 40 to 50 degrees ...” So far we haven’t experienced this, but we’ve installed a Gene Berg temperature-sensing dipstick as a back-up -
* Install a Temperature-Sensing Dipstick -
This sensor is sold by Gene Berg Enterprises. It installs in the dipstick hole and connects with a wire the oil pressure switch. When the temperature reaches about 225F, the spring inside of the dipstick turns to make electrical contact, and the oil light in the instrument cluster begins to flicker. As the temperature increases, the oil light will flicker more rapidly until it remains on continuously -- which means your oil temperature is dangerously high.
Temperature-Sensing Dipstick.
This ingenious device was invented by Gene Berg and is
marketed by Gene Berg Enterprises. The dipstick is
calibrated to signal a warning at 225F (107C).
Connection to the Oil Pressure Sensor.
The wire from the dipstick connects to the wire running up
to the oil pressure warning light in the instrument cluster.
It’s easiest to make this connection right at the oil pressure
switch, using a three way connector as shown here.
With the temperature-sensing dipstick, you don’t get any indication that the temperature is rising until the oil light flickers, telling you the oil is becoming too hot; but at least you can do something before any damage occurs. The dipstick is very easy to install in the car, since it uses the existing dash oil pressure light as an indicator.
How Do You Keep the Operating Temperature Within Safe Limits?
Below are some things that you can do (short of pulling the heads and fussing with the compression ratio. Rob Boardman: “Dropping the compression ratio is counterproductive; more compression means a more efficient engine.")
* Put a larger main jet in the carburetor. A larger main jet makes for more evaporative cooling of the inlet, so the engine runs cooler. This works for an engine which is running too lean (running lean makes any engine run hotter), but it doesn't do as much good for a car which has the right mixture already.
* Make sure that the air correction jet is the right size. A feature of all open-throat type carburetors is that they tend to run over-rich as the airflow increases through them. The air correction jet is used to adjust this mixture. This jet adds air to the fuel delivery nozzle, so larger numbers mean leaner at higher speeds. With the stock Solex carburetors (or their modern Brosol and Bocar replacements), the air correction jet is usually in the 110-130 size range. If it's up around 140-170 it's running the car lean at higher speeds (it does very little at low speeds).
* Make sure the power jet (in the right side of the carburetor near the idle jet) is the right size. From the 30PICT/2 carburetor onwards (and the modern replacement Brosol and Bocar models), a power jet was added which re-enrichens the mixture at full throttle and high rpm, because the air correction jet works too well at the carburetor’s maximum airflow. Without the power jet (or with one which is too small), the engine will run lean at very high rpm and high throttle, and as noted before, running lean makes the engine run hot. The most common power jet size is 65. The power jet feeds fuel, so larger means richer.
* Make sure the cooling vanes and thermostat are working properly and that the connecting rod is shaped properly to prevent binding between the cylinder head fins. When you have the engine out, make sure the flaps are opening easy and all the way -- you may have to unscrew the push rod from the thermostat, but you should then be able to push it up and down easy enough and check the flaps.
Cooling Vanes(3)
This picture is looking up into the fan shroud on either side, where you can see the moveable cooling flaps. The connecting rod is also visible; this rod is moved upward by the expanding thermostat to gradually open the cooling flaps. Fully open, the flaps properly direct the flow of cooling air over the engine cylinders and heads. Please don’t remove the cooling vanes and thermostat -- they provide a very important function.
Old-Style Thermostat(3)
This is the stock “bellows” style thermostat, shown installed. These are not longer made and are becoming increasingly rare.
The original style thermostat is no longer made and is becoming more and more difficult to find. A very good option is to use the new-style thermostat pictured below. This thermostat is the original replacement style for Mexican fuel-injected Beetles made from 1975 to 1979 and is a suitable replacement for the old bellows-style thermostat. The thermostat provides enough upward movement of the connecting rod to fully open the flaps on both Type 1 and Type 4 applications.
Note: The fan associated with the "doghouse" oil cooler provides plenty enough air to cool up to about 80hp (a warmed up Type 4 engine in a Bug for example), but to get best effects you have to ensure every bit of cooling air goes where it's most needed. That means you must have the cooling flaps above the cylinders -- with these fully open more air is directed to the hotter heads and less to the cooler cylinders. The cooling flaps also work with the thermostat to provide a fast, even warm-up on those cold mornings. The importance of cooling flaps used to be misunderstood and many have been removed by engine builders as “not needed”, but they are essential in getting more air where it’s needed most – the cylinder heads.
New-Style Thermostat(2)
The “Mexican-style” thermostat, used in ’74 - ’79 Mexican Bugs.
New-Style Thermostat Installed
Fortunately the “Mexican-style” thermostat perfectly
replaces the older bellows style and is very easy to install.
* Test the oil cooler and replace it if it is plugged. Make sure the "Hoover bit"(4) around the bottom of the oil cooler is there. This is a roughly L-shaped bracket which seals off the underside of the oil cooler on doghouse engines, preventing spillage of cooling air back into the engine compartment. A lot of folks don't realize just how important this piece is and remove it.
The “Hoover Bit”(3, 4)
This piece, which wraps around the bottom of the
oil cooler and prevents spillage of heated air back into
the fan, is often removed and discarded. The piece
must be left in place to assure that hot air is not
sucked back into the fan.
Note: Be careful not to over-torque the nuts on the oil cooler studs – you might squash the small rubber seals too much and reduce the oil flow through them.
* Make sure the drive belt is properly adjusted, but not TOO tight -- you don't want to ruin the alternator bearing. A half-inch deflection in the center of the belt, when pressed with your thumb, is about right. You'd normally start off a new belt with 3-4 shims and work up to 5-6 shims as the belt wears. Replace the belt as soon as it shows signs of wear – cracks or fraying. Always carry a spare fan belt – without it your engine will fry in minutes.
* Use the stock black valve covers on the heads -- black covers radiate heat better. We've heard it said that using the stock black valve covers will reduce the oil temperature by as much as 30F (17C). Fancy valve covers might look good, but the stock ones are better for correct engine temperatures. (Years ago VW used to supply an arctic kit for engines to be used under very cold conditions. This kit included chrome valve covers to keep heat IN the engine.)
Stock Black Valve Cover
We removed our “cool” shiny aluminum valve
covers and went back to the stock black ones.
We’ve noticed asignificant decrease in the
engine operating temperature as a result.
* Make sure the tin is properly fitted around the oil cooler to assure heated air from the oil cooler is being dumped to the outside, not back into the area in front (front means front of the car) of the fan where it can be sucked back into the system.
* Make sure all of the engine tin is fitted properly and all of the seals are in place to assure that only fresh air is being sucked into the engine compartment and thus into the fan -- not hot air from under the engine. This includes the seal around the engine, the engine lid seal, and any holes in the tinware. Doing this will reduce smell in the cabin when the heaters are on, too.
Engine Tin(5)
This great exploded view of the engine tin, courtesy of
the Old Beetle Home(5), shows all of the tinware
pieces,each specifically design to maximize the flow
of cooling air. Please leave them intact!
New Engine Seal
An excellent replacement for the stock rubber seal,
especially if you’re having trouble with the seal falling
down onto the muffler around the rear.
Sold by Aircooled.Net.
Note: Dave installed a fiberglass rear apron on his '73 Super Beetle. This apron does not have the slot for the stock rubber engine compartment seal, so the stock seal would not stay in place but kept falling down onto the muffler. Dave discussed this situation with John Connolly of Aircooled.Net and decided to go with an alternate seal that John recommended, shown in the picture above. This seal is used in the 1972 and newer Type 2's and the Type 4 VW. The seal is just pressed down into the space between the engine tin and the body of the car.
* Make sure the rubber air dams around the spark plug leads are in place. We’ve heard it reported that there is a 25F (14C) rise in head temperature with these left off. They harden with age and can then slide a little way up the plug lead, resulting in a lot of leaking air. If they are not soft and flexible, replace them.
* Make sure the deflector plates under the cylinders are in place. There is a small flat plate on each side, between and under the cylinders, and an even smaller one under the center of each cylinder head (on the right side the under-head deflector has a slot in it for the thermostat pushrod). These are vital for good cooling. They force the cooling air through the underside finning -- without them the cooling air spills straight down and does not provide much cooling for the underside of the heads or cylinders. Some folks leave them off, not realizing how important they are.
* While you are under the engine, make sure the underside plenum pieces of tinware are in place (a large curved piece of tinware under the left side and two pieces on the right so the thermostat can be easily changed). These turn the used cooling air backwards to the rear of the car. If they are left off, the underside engine finning is exposed to the turbulent high pressure air under the car and poor cooling will result. On the stock engine the cabin heat exchangers are used to dam off the outer sides of this plenum, and if you have replaced the heat exchangers with J tubes you still need to seal the outer edges of the plenum with some cut-to-measure pieces of flat metal.
* "Cool tins" are used on Type 3 (pancake) engines to improve underside cooling and can be fitted to the Beetle engine too. They replace the cylinder deflector plates (the head deflectors stay in place) and cup the underside of the cylinders so all the cooling air is forced through the underside and out through the exit holes in the tinware. They also have "ears" which cup the outer corners of the head near the exhaust valves so that those valves get a better flow of air through the fins there. They work by actually reducing the cylinder air flow a little (but using it better), and this results in a higher airflow through the heads, so cooling is improved there too.
“Cool Tin”(6).
You shouldn’t need the “cool tin” if all of the other
parts of your cooling system are in place and
functioning. But it is available at minimal cost
(e.g., from Aircooled.Net(6))and is easy to install
(with the engine removed from the car).
You have to remove the engine to install the cool tin, and to fit them to the Type 1 Beetle tinware they might need to do a little cutting and bending. They are not really needed for a stock Beetle engine, but if you have a higher performance engine or are experiencing cooling problems, they might help. (We have not personally used "cool tin" and cannot vouch for its effectiveness. It helps, though, according to the experts.)
Summary of the Ways to Increase Cooling (by Rob Boardman)
* Correct casting imperfections in the heads. If you look through the finning on VW heads, you'll often find "dags" of metal between the aluminum head finning which partially blocking the airways. (This is not a problem with the cylinders - just occasionally with the heads.) Removing these "dags" with a rat-tail file, a chisel, a Dremel, etc. will smooth the air path through the head fins, thus improving airflow and cooling of the heads.
* Use the standard VW pulley -- not a "power pulley." These spin the fan slower and reduce cooling. A “power pulley really isn’t worth it -- you gain about 1 hp at the wheels for the loss of maybe 20% of your cooling air -- a BAD trade-off).
* Run higher octane gasoline. This will help if you have been running a too-low octane fuel, but won’t help if you already use the correct octane. But don’t think “higher is better” either. A too-high octane number will not harm the engine in any way, but won’t help it run any better either. The stock 1200 and 1300 needs only 87 RON (84 AKI in the USA) and the stock 1500/1600 needs 91 RON (87 AKI in the USA). If your compression ratio is higher than stock, then you’ll need fuel with a higher octane number.
* Avoid oxygenates in the fuel. The most common oxygenates added to gasoline are methyl-tertiary butyl ether (MTBE) (used extensively the USA) and ethanol (when added to gasoline the mixture is sometimes called “gasohol”). Because old VWs have no engine computer to adjust the mixture on the run, oxygenates will cause the engine to run leaner than it should, and lean means hot. If you cannot avoid oxygenated fuel, increase the size of the main jet to return the mixture to its proper balance. For example, fuel with 11% MTBE (used in many parts of the USA) runs the engine 2% lean and a main jet one size larger will fix this problem. Ten percent ethanol in the fuel (called E10 in many countries) needs a main jet two sizes larger to bring the mixture back into balance.
* Make sure the underside tinware is in place - both the flat plate deflectors under the cylinders and the heads MUST be in place or the airflow just spills straight down and the underside cylinder/head finning doesn't see enough cooling air. Also make sure the underside plenum tinware is in place - this turns the used cooling air backwards out under the rear of the car. If it's missing the cooling air meets turbulent high pressure air under the car and this can reduce the engine cooling.
* Make sure all tinware holes between the upper and lower engine areas are sealed, so there is no mixing of hot used cooling air from underneath with the fresh cooling air above the engine. There is also a very important piece of tinware under the oil cooler - called the "Hoover bit" by a lot of VW enthusiasts - after Bob Hoover in California (a VW Guru). It's roughly L shaped and it is attached to the base of the oil cooler with one bolt and seals the oil cooler so you don't get any spill of cooling air out the bottom - it must then all pass through the oil cooler. Also check the rubber air seals on the spark plug leads - these go brittle with age and might get pushed up the leads and fail to seal off the holes in the tinware where the plugs sit. Leaving these holes exposed can increase head temps by up to about 25F.
* If cooling is still a problem with just the (well fitted) stock cooling system, then fitting cool-tins might help. These were originally designed for the type3 (pancake) engine with it's more convoluted cooling path, but can be used on the upright cooling system on the bug too. They replace the under-cylinder flat plate deflector (the smaller under-head deflectors stay in place), and they control the airflow around the cylinders much more closely. They also have "ears" which cup the undersides of the exhaust valves for better cooling flow around these hot-spots. To fit to a bug there is usually a little cutting and bending to do, but it's not a hard job. The underside plenum pieces (which turn the used cooling air backwards) must still be used. These cool-tins actually reduce airflow around the cylinders a little (but use it more efficiently) and the resulting increase in pressure in the shroud above (from the reduced airflow) provides more airflow to the hotter running heads, for better cooling all round.
* If you are runing a car with a solid engine lid (up to and including the '69 lids), and you have a 1600cc (or larger) engine with the doghouse fan shroud and oil cooler, then your engine WILL run short of cooling air at higher speeds. VW started adding slots to the engine lid from 1970 onwards, first two sets of slots in '70 and '71, then four sets from '72 onwards, because the doghouse fan shroud (from '71 onwards) has a 10% higher airflow than the non-doghouse fan, and the under-window slots were not quite big enough. As an example, my '68 with 1600cc doghouse engine (bigger fan than the '68 1500 engine) runs too hot in summer with the '68 solid engine lid, but much cooler with the 2-slot engine lid borrowed from my 1970 bug (whilst it's being slowly rebuilt after loosing a fight with a nasty Ford).
* Some think that installing an oil sump will bring about greater cooling of the oil. All of the advertisements say that adding a sump increases cooling; however, Gene Berg says it just gives you more hot oil and is only advantageous in racing and hard cornering applications (to prevent oil surge -- not to increase cooling). The surface area isn't much more for additional cooling, and you also loose a couple of inches ground clearance. Oil sumps are good for racing, but not for cooling.
* An oil temperature guage is always a good idea, but don't get hung up on the actual number because it will vary with the engine, the quality of the guage and so on - just using it for a while will give you an idea of what is normal for your engine in different driving styles, and then if you see if above the "normal" you will recognise it as such.
* One very simple idea is to install a Gene Berg dipstick. This replaces the normal dipstick and one wire connects to the oil pressure sender just behind the engine pulley on the left side of the case. This sensor will then start the oil pressure light in the dash flickering at about 215F (I think - I forget the exact number) and turn it on steady at about 225F (or something like that). The oil light will still come on steady if the oil pressure drops too.
* So you don't get much indication of the temp starting to rise, but you get a good warning once it's become too hot, and you can back off the power, change down a gear on a long hill climb or whatever, before the engine gets REALLY hot.
* Driving style can certainly affect the engine temperature. Constant hard acceleration and braking will heat the engine. If you have to brake hard then you’ve just used more engine power than you needed. Always shift down a gear before the engine starts to lug on long hills or when towing a heavy load -- this unloads the engine and increases the fan speed for better cooling.
* Regarding cooling the engine while driving – we’ve occasionally heard of people driving at low speeds in 4th gear -- low rpm -- to reduce the temperature of an overheated engine. In fact it works just the other way around. Since the oil cooler is in the cooling fan's air stream, the best way to cool a hot engine is to cruise gently in 3rd gear rather than 4th. This way you don't ask for lots of power (heat) from the engine (up to a nice steady 40mph is fine), and 3rd gear keeps the cooling fan’s speed up, which helps both the oil cooler and the cylinder head temperatures.
There you have it. Use all the stock parts of the cooling system, properly fitted and without any exposed holes in the tinware, use the right fuel, set the carburettor mixture right, drive sensibly, and your engine will run in its preferred heat range in summer or winter.
Credits and references -
1. Courtesy of Gene Berg Enterprises.
2. Courtesy of California Import Parts, Ltd.
3. Courtesy of Stephen Gutknecht -- [email protected].
4. Courtesy of Bob Hoover -- This piece is referred to as the “Hoover bit” because of Bob Hoover’s discussion of it in one of his “sermons” on the subject of cooling. Unfortunately Bob Hoover’s Sermons are no longer available on the Internet.
5. Courtesy of The Old Beetle Illustrated Parts Catalog.
6. Courtesy of Aircooled.Net.
wow..i really need to copy n paste this stuff..there's a lot and i cant read it throughly...hehehe
guys...still progress with customize front n rear disc brakes....opss...n the alarm system..
bro vwmania..can send me some detail bout the front n back disc brake customization..need to see to get a clearer picture..or else my dad dowan to fork out his money..ehehe
