VVTI on Kelisa type engine
mag9556
Taiko taiko..
Just wanna to ask that currently I am using Kancil with (Kelisa type) L5 engine turbo..
my problem is since that both Viva engine and Kelisa engine is nearly the same..
Can I swap the VVT inside my engine? possible or not arh?:hmmmm:
Kindly share some info here..:biggrin:
maybe need the whole wiring and ecu ...without this thing ur VVTi won`t activated...
Just bought a new VIVA,
can anyone tell me where the fuck is the sparkplugs ??
damn car, cant even see where is the spark cables.
I got open the air box, see got 3 electric thingy adopter thingy, got related to the spark plugs a not ?
damn car . . .:mad:
sure got spark plug.
newer engine usually use electronic type ignition.
the "electronic box" on top of the engine is "ignition coil" for plug.
one per plug.
y? u wanna change plug cable izzit? hehehe
mag, what do u mean by swapping the VVT to ur engine?
the whole engine head is needed, plus cams of cuz...and i dun think it will match with the L5's block (correct me if i'm wrong)...wiring and all of cuz is needed..
it will be sumthin like matching a mivec head + a 93p block...
cheers
damn car . . .:mad:
lolx google up for Coils On Plug
its 3 sockets on ur engine head , under that is ur spark plug cable , under that ur plugs
cheers
Bro..
Coz what I knoe is this engine is using chain belt and mine using normal belt just like Kelisa.Somemore do not sure that this engine head can put inside L5 engine or not.
What I knoe my engine and Viva engine also 3piston only...:biggrin:
Tha's why I ask any taiko in Zth that knoe about this or not...:itsme:
Actually I am plainning to wait for those total lost Viva and taket their engine head and wiring thus ECU to put it inside my Kancil...hehehehehe...
damn car . . .:mad:
Take out the air filter and the head plastic cover..
After that u will saw coil that screw... open the screw u will see the plug...hehehe...
first time i see plug cable liddat one :mad:
got 3 little wires instead of 1 big cable
tried opening the plugs, damn it, kenot wan, dunno why so tight :mad:
damn lousy engine, response super slow, gear change oso super slow :mad::mad::mad:
wanna change to platinum plugs and air filter, hope it helps to make the response better
just now my fren from indo told me its distributorless ignition, DLI :hmmmm:
