Upgrading brakes system
Agl
Outerspace
Hi,
Am planning to upgrades my car braking system, any idea or suggestion? I think i need to find the double layer brake servo n the pump as well either from vr4, evo or pajero.
Thank you.
upgrade servo pump 1st...then if u want the pedal soft to the touch of your leg...upgrade to larger brake caliper...or 2 pot...
agl,
what engine/car are u running? upgrading to a stronger set of brakes might be overkill!
might i suggest the following setup (stage 1 apparently)
1. pro-rs hoses/goodridge = 380/399
2. DBA discs slotted = 825/pair or axt discs = 600/pair
3. mintex or stoptech pads = about rm200 for fr and rr i think. gotta check la.
4. dot4 brake fluid
i wouldn't recommend DOT5 as it is NOT water solluble thus if water gets into ur system, ur screwed. dot4 and dot3 is good enough for almost all applications. also dot5 can't be mixed like dot3 and dot4.
good luck :)
agl...
my fren's got another set of vr4 rs brake pump...]
same..pump n servo....
rm 150 nego
yup..bought a vr4 rs nose cut...
wan the head lamp..bumper...air cond...dash board...the engine wiring ecu all ppl buy liaw..
so selling cheap cheap so my fren sapu...
I oredy got the evo one.
